Any idea when you guys will have a decent ROM up and running for it?
MK 908-II in the house! WOW something has changed for the better!
the stutter you see in that map scene is not stutter is a pan and scan in the encode its self so long as its not dropping frames or dropping audio its finecurrent devices(rockchip sucks)
Hardkernel ODROID C1 running android kitkat
Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
rPi model B+ running nothing ... bricked
Originally posted by Legitsu View Postthe stutter you see in that map scene is not stutter is a pan and scan in the encode its self so long as its not dropping frames or dropping audio its fine
1080 kernel
FYI, the latest ROM from Tronsmart for the MK908ii has a real 1080 kernel in it!
All they did was edit build.prop to make the icons look smaller etc.
Now I have to figure out how to patch backwards and make a 720 kernel as I think this will perform better for those that do not really care about true 1080 and just want best performance with right now in my opinion a 720 kernel does!
My ROM maybe ready today.
cx919 kernels work with this stick very well:"Everything is possible if we work together!
Originally posted by lewy20041 View Postcx919 kernels work with this stick very well:"
There is FOR SURE something different here and it may have come from RockChip!
There are SECRETS in this stock ROM!
The build.prop still has LCD density at 160 yet..... it is a 1080 kernel!
It is reported by Antutu as a 720 resolution! Why? hahahahaha! I now know why!
Framework-res.apk has images all created to support 160 LCD density BUT at 1080. Antutu triggers on this as well as other apps! This is a tweak I have never seen before.
Lewy, be careful porting minix stuff here. Kernel is stable stock but certainly NOT with this new framework, etc. This is a different thing for sure!
I am telling you guys right now, there is some interesting stuff here and I am sure this came from RockChip!
How they got a Antutu benchmark of 18K at 1080P is a cheat!
I got a lot of work to do boys and girls. This is a new animal for sure. Give me some time.
Learned something new
OK guys let me explain.
In the past if I made a 1080 kernel..... to make the icons, text, etc look like a 720 kernel we always edited this in build.prop:
This supported 720 kernels:
ro.sf.lcd_density=160
This supported 1080 kernels:
If you used a 1080 kernel and wanted the same sized icons and text you edited build.prop lcd density:
ro.sf.lcd_density=240
So it seems we have another build.prop directive!
The MK908-ii did not edit LCD density with a 1080 kernel! And this spoofed many apps to not know we are running 1080p including ANTUTU tests!!!!
video.use.overlay=1
This makes the icons, text etc seem like 720p! It even spoofs Antutu into thinking it's running at that resolution and thus very high Antutu scores! It's a lie! But how?
If you set to this:
video.use.overlay=0
and leave LCD Density at 160 (small icons, text etc) then Antutu is much lower scores!
Now the question is...... what the hell does this mean in the end?
A 1080 kernel that is not drawing as many pixels? I don't know but much more testing to find out!
I cannot find much on google or anywhere else about what the hell video.use.overlay does!
But for sure it has interesting changes to how the Android OS performs!
Keys to the kingdom!
I think I found the keys to the kingdom BUT ONLY with a latest kernel.
This build.prop directive has a HUGE change in video performance!
New ROMS is set to
sys.hwc.compose_policy=6
MK908ii this is set to 0.
HOLY COW! Does this change video performance!
Now these I do not believe are standard Android directives but in fact RockChip directives!
I have MUCH MUCH testing to do as I am sure these directives change how Mali works with HW decoding and the kernel itself!
This is getting FUN now!
Originally posted by sistemika View Post@Finless... Do you recomend buy this device? I have a MK908 v3 but I'm unhappy with it...
Thanks a lot.-
Originally posted by Finless View PostDude... I personally hate questions like this.... BUT.... Tronsmart just released an updated ROM for the MK908 (I don't know if it supports V3) and I bet you a million it has these tweaks in it! So stay tuned. I will be doing a ROM for that. But please.... don't ask me about what to buy. I don't like answering that question!
Thanks again and Sorry.
Regards.-
IMPORTANT!
Wow.... for sure there is a kernel change here in the MK908ii
If you try older kernels from our Dev's here or CX-919, and you don't set these to directives in build.prop right, shit will be all F'ed up! and I mean seriously bad with garbage video playback!
ro.sf.lcd_density
video.use.overlay
Now on older kernels, changing some of these values has NO EFECT! This is why I am sure there is a kernel change and I think this IS from RockChip!
I am starting to think we might be seeing a SDK2 morph here. Unfortunately the combinations of all this and different kernels are tweaking my brain right now! Too many combinations!
BUT I am giving you guys some hints on what to play with!
I could use some help testing this stuff and combinations!
Originally posted by sistemika View PostSorry did not mean to offend with the question. It's just that I want a device that works well with Netflix and the WIFI will not falling down. My intention is not offend, only I want to buy a device that works well.
Regards.-
Trust that whatever the outcome, you will reap the rewards. The Dev's need to now look into what I am finding. Your V3 may turn out cool! Just hang tight please.
There are currently 2124 users online. 1 members and 2123 guests.
