PMID701C TV Out
Originally posted by helpless automation View PostI just updated my 701c to the ST ICS upgrade and I can use the tv out with no problem. So yes the upgraded ics does do tv out if you have the port.
Originally posted by SingleDad View PostPolaroid went out of business long ago and just sold the name and rights. The Polaroid name will live on with S.T. or whoever else buys the rights to it I suppose.
Originally posted by firstparadigm View PostI bought the following for $5.00 and it works well. I guess it's originally for INOi or Argosy HDD Media Player. I had to swap the plugs around once to get it right and unfortunately I'm not at home to see where each went.
http://www.amazon.com/INOi-Media-Player-Component-Cable/dp/B001EUEVX2/ref=sr_1_1?ie=UTF8&qid=1334334365&sr=8-1
I've run into two issues, neither of which I believe is a result of the cable:
The first is a bright green line that runs along the left and top edge of the output. I haven't adjusted the TV settings or anything to try to get rid of it, so perhaps that would help.
The other is that when I connected a 3.5mm male to red/white RCA cable to carry audio, the internal speaker did not turn off and the slight delay in transmission caused a very irritating "echo" effect.
Has anyone run into these issues?
There are currently 5417 users online. 3 members and 5414 guests.
