[RePack] Finless 1.4A for the MK908 V3[UPDATED]
    Rom is working on my mk908 v3.
    Installed xmbc, but it does not open ifo-Files. So I can only start movies by starting the vob-files.
    I anybody help me solving this problem?
      I´ve been testing it for a while, so far is working great!
      Thanks for the effort.
        Thanks for your work and effort.
        Unfortunately, I get the same results as with Hoabycsr's custom ROM but much faster (antutu about 16650) : everything is perfect (I have not tested the Logitech cameras) except wifi which the flow varies continuously.
        I have no problems with other Wifi connexions and it's not problem with channel or sensibility (-30db).
          AW: [RePack] Finless 1.4 R2 for the MK908 V3
          On stock firmware i realized that wifi problems only occurs while Bluetooth is enabled. So if you don't need Bluetooth, just disable it for a while to see if it changes anything for you.
          _________________________
          tapatalked from GalaxyS3
            I do not use BT, it has never been activated...
              this is the stock tronsmark-kernel because its the only kernel that works correctly on the V3 sticks
              their is nothing I or anyone else can do about the intermittent Wifi/BT issues its a kernel issues and we currently don't have sources to build for the V3
              also AP6210 chip operates best when using N-Wifi G-wifi is unstable due to the small antenna
              current devices(rockchip sucks)
              Hardkernel ODROID C1 running android kitkat
              Hardkernel ODROID XU3-L Running Linux/openelec (primary media server)
              rPi model B+ running nothing ... bricked
                WiFi Not as stable as the Stock
                I have a Tronsmart mk908 v3 motherboard. when I was running the original Rom Wifi would connect to N be consistant even with BT on. Now I installed this Rom and seems as tho the WiFi took a major Hit, it consistantly Drops to 5mbs and when it connects at 54mbs and I do a test with speedtest.net it only achieves 5mbps transfers.
                But that is what I notice is the WiFi radio is taking the biggest hit with this rom maybe the power is lowered is there a way I can transfer more power to the Radio?
                also 1080p video after a bit freezes my system.
                Thank you so much for building this Rom.
                also the video according to the benchmark Anututu is showing only 1920x1032 why is it not full 1080?
                Last edited by buckbullstallion; 25 September 2013, 22:13. Reason: additional findings.
                  I do not speak English, but this did to improve wifi reception in MK908 V3 and it works wonders!!
ID:	430823Click image for larger version
ID:	430822Click image for larger version
                  The antenna's kick another unused gadget
                    [ATTACH=CONFIG]3396[/ATTACH][ATTACH=CONFIG]3395[/ATTACH][ATTACH=CONFIG]3397[/ATTACH]
                    That looks a bit "Russian" as we say in Austria, but could be working... Wed need to find a good length of the antenna and could then have just one wire to work like old wire antenna for FM radio...
                      Sorry, I only speak Spanish and the translation of google not allowed me to understand what you posted....
                        RamSpeed=400Mhz MAX
                        CpuSpeed=1600Mhz MAX
                        ? isnt this going to practically make the device burn ?
                        what are the speeds on the stock rom?
                          Originally posted by Ridata View Post
                          RamSpeed=400Mhz MAX
                          no those are the defaults
                            Can you please implement the auto hide systembar feature?
                            I really love it (without it XBMC won't play fullscreen)
                            L.
                              New version: See first post
                              ChangeLog:
                              *fixed Developer Options being missing from the menu (**** you china)
                              *Added ockernel.img(mild overclock 667 Ram 1600Cpu 533 GPU V3 ON with the VSAM fix) V3 ONLY!!!!!!!!!!!
                                Thank you Legitsu for your work, CPU scaling works ok like in last stock rom, but I have issue with XBMC, can't play 1080p in internal player, many frames dropped, MX plays fine, smooth video. Can anyone else confirm that? For now, the best result I had with Hoaby 1080p v3.5 fast, system was very fast, XBMC worked without issues, but there was no BT and CPU scaling problem. I don't know what he did, but it was pretty amazing. Don't get me wrong, I appreciate your efforts
