Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by nick549 View Postplease help me with the activation mac: 04-81-90-31-29-C2
AndroidPCtv.com tutorial on how to properly install Allwinner images:
*Note: the tutorial only highlights SDcard tool and USB-Pro tool for [.img] installation methods.
Originally posted by suoko View PostWhat guide did you follow to have Netflix on Kodi?
Also, what Netflix apk are you using on the x96 mini? Why can't you install that on the TX6 too?
Inviato dal mio Redmi 4X utilizzando Tapatalk
i dont know whitch netflix apk it is on the x96 mini, so far i know is that the app from the playstore, and the tx6 and the netflix from the playstore is not working its not compatible.
Originally posted by RiCkLaR_atvX View PostI don't know why everybody keeps running into the problem.
The problem occurs if the box TX6 and firmware Tanix TX6. or vice versa, boxing Tanix TX6 and firmware TX6.
Checked a million times, the firmware method has nothing to do with it
Originally posted by kruijf View Post
There is a guide on the kodi forum but you can find it also true google, dont take the netflix repro from tvaddons.co that one is not working.
Are you able to upload somewhere the build.prop file of the x96? I want to try to pretend my tx6 is an x96 and see if the official Netflix works this way.
Also another question, is the x96 rooted?
Originally posted by Hikvision View Post
Originally posted by suoko View PostMaybe it's just a question of build.prop or root.
yes the x96 is rooted.
Originally posted by mike808 View PostI wish I had read this thread before ordering two of these boxes, they're already on their way, I got the 4/64 version with dual wifi and bluetooth. The only things I'm interested in running on these is stbemu and kodi, anyone have any problems running those two apks on this box?
Hikvision helped me. He told me this: I personally love Android 9, I recommend 20190613.
To do this, you need to fill in the software 20190506 and update the OTA zip 20190613.
Or, good software android 7 - 20190625. To do this, fill in the software 20190123 and update the OTA "by air" to 20190625.
I took his recommendation and installed Android 9 and the update. Everything is working great.
Guest
Tanix tx6 arrived today, first time using android tv, sound not working anywhere, tried updating no update found, fml
Guest
Guest i was thinking about getting one of these box's but....you are saying you got a new one and it has problems?..does everyone that owns one of these Tanix TX6 have problems?
not sure if i should get a Tanix TX6
There are currently 2188 users online. 2 members and 2186 guests.
