Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by SoteR2110 View Postyup, thats it, why?
If in the name of the firmware file only the inscription TX6 will be "balls", and if there is a word Tanix, then there will be a video animation
eg
Tanix_H6_9 4Gddr_8822bs_20190228 - video animation
TX6_H6_9.0_4Gddr_8822bs_20190228 - "balls"
https://chinagadgetsreviews.com/down...x6-tv-box.html
Originally posted by Hikvision View Postbecause there are two firmware from 0228 - see my table )))
eg
It seems like Kodi cannot keep up the buffering and the playback speed. I don't know whether it is the wifi that is too low, or the update, or the kodi, but I'm very sure it is not my internet speed since when I streamed the exact same file from the exact same server using the exact same wifi on my laptop with Kodi 17.6, there is no such problem, only on my TX6 box.
I've updated my box to your 0507, but now I have Kodi buffering problems, when I stream HD videos in kodi, it will play for several seconds, and then buffering for few minutes, and play again for several seconds.
Enviado do meu POCOPHONE F1 atrav?s do Tapatalk
Originally posted by Hikvision View Postmemory chip is not damaged - just reflash using memory programmer - need to solder
Originally posted by Hikvision View PostOf course you can - tomorrow I will definitely appreciate the software
Exactly what is your role here? Are you trying to help people out or not?
I have no idea whom to make this request to, I thought perhaps it was you. I have no idea where to get source and neither does superceleron. A new kernel build is required with touchscreen support requested. If you can help great, if not, just say so. .
Originally posted by scooterTX6 View PostAfter reading your response it seems like you're trying to be funny. It's not.
Allwinner and Tanix are the only ones with the source code and SDK, they won't be releasing it to the public, because its proprietary software not open sourced. Ask directly to Allwinner if want source code, good luck.
Don't think Tanix will release touchscreen support for Android 9 anytime soon, when the main purpose of this device is to be hooked up to TV monitor; and asking for touchscreen support directly from Tanix will probably never get answered or fulfilled.
What use would it be anyway? 99.9% of TX6 and other devices like it use *A NON--TOUCHSCREEN DISPLAY* for video and that's not going to change anytime in the near future.
Originally posted by RiCkLaR_atvX View Post
Looking at the Screenshoot, it clearly looks like the Changelog include with an OTA directly from Tanix.
Originally posted by Hikvision View Post"I am part of that power which eternally wills evil and eternally works good.?
touchscreen on TX6 - fiction
There are currently 1396 users online. 3 members and 1393 guests.
