Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Latest TX6 firmware - tx6-9.0-20190615 (for 2*16)
Attention !!!
There is no certification сервисов GOOGLE in the firmware - no login google
You can register yourself, there is a method
But in Aida64 now writes ALLWINNER )))
https://drive.google.com/drive/folde...9-n1XbhiKl3pmr
Originally posted by Hikvision View PostLatest TX6 firmware - tx6-9.0-20190615 (for 2*16)
Attention !!!
Is it possible to fix the Google Store with the modded Store from Lucky_Patcher app??? Or if TWRP installed then fix Google with NanoDroid.zip ???? If you never heard of NanoDroid search GitHub, it is nice firmware modification programming, has some Google fixes coded into it.
Originally posted by thuongshoo View PostTanix can provide the drivers via their OTA.
Can we backup the driver then move it to 0508 ?
Originally posted by c,lei View Post
Um, why? The standard TX6 (Dual WIFI) doesn't need these drivers and the non-standard TX6's have their own firmware. You shouldn't be flashing a non-standard TX6 with the standard TX6 firmware if it doesn't match the hardware you have anyway (Single vs Dual WIFI). If you do so, more fool you.
Before I decided to buy Tanix, I found it has been produced tv box for a long time. However the way it make firmware really surprise me.
Samsung is making a lot type of phone for a lot of country, but user never care whether a firmware is suitable for their phone.
Originally posted by thuongshoo View PostThere are a ton of software applications inside a firmware, not only Wi-Fi driver. Wi-fi drivers often only some small files. Software itself know what driver should be used. How can it do when there is no the needed drivers?
Originally posted by c,lei View PostUm, why? The standard TX6 (Dual WIFI) doesn't need these drivers and the non-standard TX6's have their own firmware. You shouldn't be flashing a non-standard TX6 with the standard TX6 firmware if it doesn't match the hardware you have anyway (Single vs Dual WIFI). If you do so, more fool you.
But I bought a TV box not for watching videos and so on, but to increase my knowledge and communication on the forums)
Originally posted by RiCkLaR_atvX View PostDo you have the firmware currently installed and testing? Any other negative things?
I registered the TV box on the GOOGLE website and services started working - very simple - 5 minutes of time
No TWRP for android 9 !
Originally posted by Stefanmic74 View PostHi Hikivision.
I flashed Your last posted firmware to my TX6 4*32. Now I see "This device is not activated....".
MAC address is only 02:00:00:00:00:00
How can I fix it.
Thanx
my message number 175 - page 12
Originally posted by Hikvision View PostWhat kind of software did you install and what inscription ?
This device is not activated yet, please contact your vendor ?
Then I have this messege: "This device is not activated yet, please contact your vendor"
This firmware I installed: tx6-9.0-20190615.img.
You have two problems - the inscription at the top of the screen and google services
I have already returned to 0419
Originally posted by Stefanmic74 View PostI am back to Tanix_H6_4Gddr_8822bs_20190323.img. Bot now I can not uptate via pre-installed app to 0419
There are currently 1383 users online. 2 members and 1381 guests.
