Link to the firmware I wrote to you
Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by c,lei View Post
Ah. Seems the TX6-A only has 2.4G Wifi:
Seems people aren't actually reading the WWW pages of the sites they are buying stuff from these days.
This page for instance says Tanix TX6-A Allwinner H6
https://www.banggood.com/Tanix-TX6-A...erica&ID=53360
instead of Tanix TX6 Allwinner H6 like this one does
Originally posted by kruijf View Post
I dont care about that the problem is that cant turn the wifi on
Originally posted by RiCkLaR_atvX View Post
You should have payed the extra dollars to get the better wifi unit in the more premium TX6 standard 4GB/32GB model. The "TX6-A" or "TX6-mini" are lesser value products, in the budget category that means you will get the cheapest internals possible, and it will still look similar on the outside to the premium model. As we have already seen only the standard TX6 has received any support.
when i buy a new one i buy it by another seller so i get the right one.
Originally posted by Hikvision View PostYou also have a budget model ? )
I asked you to show the sticker
Originally posted by Hikvision View Postwhat version of software do you have now ?
Dropping frame issue still occurs but just random or intermittent. I guess that CPU temperature is too hot then some frames are dropped but CPU become cooler than it can work well. Then the sequence repeats
Originally posted by thuongshoo View Post
Both 0507 and 0508. It can only work well within 1-2 days. Maybe my room is quite hot because I live in a tropical climate and no aircondition.
There are currently 2278 users online. 0 members and 2278 guests.
