You can open the activation panel by pressing the button 758523 on the remote control
Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by chenrp View PostI?m thinking the h96 max with the s905x2 is bettering?
Fantastic thanks! Thank you! Thank you! It works .Please, I need 4 code to activate the other 4 boxes Thank you!
Mac: 048190301600
s / n: csh6622b302626
Mac: 0481903015d0
s / n: csh6622b302979
Mac: 0481903023be
s / n: csh6622b302613
Mac: 0481903016a7
s / n: csh6622b302602Last edited by Pierre Rousseau; 14 May 2019, 23:41.
For those who have the inscription when changing software - This device is not activated yet, please contact your vendor !
The way to activate boxing is taken from the forum 4pda, thank you very much surkov.alex, jjonas and dortmundez.
1. Open in the browser - https://pastebin.com/raw/nGZwxgrW - copy all the code
2. Open in the browser - https://ideone.com/ - delete the entire code in the window and paste the code copied in step 1
3. At the very end of the code we find the string - System.out.println(new SyncTask().sync("0A-0B-0C-0D-0E-0F").substring(0, 8).toLowerCase())
and in place 0A-0B-0C-0D-0E-0F write down the MAC address of your box (if there are small letters in the MAC address, write them in capital letters !!!)
4.Push button Run, the script is executed and at the bottom of the page, under the inscription stdout, we get our activation code.
5.We turn on the box and on the main page dial the numbers 758523 on the remote control of the box and see the activation window on the TV screen
6.Enter your activation code in the Code field and click on SET - The inscription at the top of the screen should disappear.
the instruction is long and the process itself takes one minute maximum )))
Originally posted by Hikvision View PostFor those who have the inscription when changing software - This device is not activated yet, please contact your vendor !
Thanks for posting this. It's really interesting to see something like this.
Hi Guys, I have a TX6 and everything is fine but I have a problem:
Playback of 4K movies on Kodi 7.6 is slightly choppy/jerky/not smooth. SPMC produce the same result. It's hard to tell but it's not perfect. I tried enabling sync to refresh rate but is the same. Debug info show 0 dropped frames.
I'm using 4K/60 hdmi output.
Kodi 8.2 is very laggy and unusable.
Anyone know how to fix?
Missing the nav bar on my newer Android 8 & 9 boxes . added Simple Control. it's on goggle play or older versions at https://apkpure.co/simple-control/. I went with the oldest version. it removes itself (goes down) after a few seconds after pulling it up. happy
Hope this helps someone else.
Originally posted by bortao View PostHi Guys, I have a TX6 and everything is fine but I have a problem:
There are currently 6804 users online. 0 members and 6804 guests.
