in the file build.prop you can change the name even to AMD Ryzen Threadripper 2990WX
Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by Hikvision View Postdo not pay attention to the inscription in Aida )))
The box still translates everything to PCM but with fiddling was able to get it to do multi-channel in most apps . . .well, a couple; VLC still passes thru PCM stereo, Kodi does nothing at all, MX says cannot support audio format . . .
As a 1080p box the picture quality is fine, not as good as the N6 Max but near excellent.
The SPDIF is soldered in properly but it is dead - no output that I can detect.
Warchild, from what I gathered from around the internet it seems that one or more firmware versions is the cause for disabled spdif.
If people with tanix tx 6 that has a working spdif and a tanix running android 9 could be so kind to check to see which firmware version you are running that would be very nice of you. I will try to flash a firmware upgrade as soon as I know which firmware version that will enable and activate the spdif out from tanix tx6.
Got stuck'd in the recovery screen. Even when I try to reboot I can't seem to get past the recovery screen. So then I tried to a factory reset and after that I rebooted. Rather then booting into Alice UI I ended up in the recovery screen again. So now I don't know how to boot back into the GUI again.
Any ideas?
Originally posted by blackholesun View PostWarchild, from what I gathered from around the internet it seems that one or more firmware versions is the cause for disabled spdif.
i also stuck in recovery screen, only thing that helped was :
1. forget about alix ui or what it?s called and android 9
2. download Android 7 custom rom from superceleron
3. put the image to SD card with phoenix card 3.1 or so....
spent 10 hours with different way, Android 7 image on sd was the only way to recover.
Now i?m stuck with rom on androi 7 but no access to Play Store...
BR
usti that does not sound good, seems these units are a bit sensitive. Being stuck in recovery mode, and no way to enable the spdif audio out. I can't help but wonder, how in the world did these units pass the QC at the factory?
Are there anyway to get out from recovery mode without downgrading to android 7?
Android 9 was buggy and unusable and I tested them all version. An Android 7.0 firmware works fine, but an activation message is displayed and the system restarts after 30 minutes. Do you have a solution to activate it Thank you very much.
I really have deep pity, for those who uses Android 9 on TX6 total bug.You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by Pierre Rousseau View PostAndroid 9 was buggy and unusable and I tested them all version. An Android 7.0 firmware works fine, but an activation message is displayed and the system restarts after 30 minutes. Do you have a solution to activate it Thank you very much.
There are currently 2189 users online. 1 members and 2188 guests.
