Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by Hikvision View Postwi-fi works absolutely on all softwares
0114 - 0122 - 0228 - 0323 - 0401 - 0404 - 0418 - 0419 - 0508 and so on 0506 - 0507
ate you box 4 + 32(64) !!!!!!
Originally posted by Hikvision View PostDon't understand what Thuongshoo is doing )))
I get it by flashing 0228 then using the update application
Originally posted by Paulo Saraiva View PostI recently bought this tv box and i've got some issues
- This box SUCKS in Iptv...the image constantly freezes with IPTV EXTREME. I previously had a Beelink GT1 Ultimate and had no such issues with the same iptv link and same app
- I have a Mele F10 Deluxe and the home button doesn't work. Again...it worked ok on the Beelink box i had before
- Box came with Netflix working...after a update it just doesn't start and i've tried to install a different apk but it just exits without even showing me the netflix start screen
I opted for this one cause on paper it looked like a cool box and my Beelink GT1 Ultimate was lost in Android 6 and i haven't been able to update it. This one came with android 9 but these issues i mentioned are annoying me and i can't understand how a 4GB RAM box has them.
Can you guys help ?
Â
Originally posted by Stefanmic74 View PostMy Tanix TX6 4GB/32GB, Android 9 (last update 04-2019) has lot of issues:
- Audio 5.1 by HDMI goes only in stock video player. Is not possible to set 5.1 sound in Youtube, Kodi, MX player... There it plays only 2.0 sound. (I tried android 7, but there with vidieo files with 5.1 sound was no sound). I tried SPDIF, no help. (My previous box TX3pro works with audio 5.1 fine)
- 5.1 audio has horrible quality.
- Notifications is not possiple pull down. If I used application to show notifications, is not possible to interact them (not clickable)
- if box is turned off, USB sending power to external HDD and it is pernamently working
- od 8th May 2019 was released OTA update (presented on FB page), but my device still shows in pre-installed update app: "Undiscover new version" (Can someote post link to download update.zip file?)
- WiFi randomly disconnecting
- Is not possible to set main home launcher. If I want to use different launcher, box boots in Alice
Yesterday I flash 0507.img (from megaupload URL) then the update application also says that it is the latest version.
Originally posted by Hikvision View PostAnd it turned out that updating software is very simple, fast and safe.)))
If you need a digital audio output, use software from EACHLINK H6 Mini .
you only need to replace the remote control config - this is very simple. And the display will not work
Hi there guys and girls, one more rom/fw for you all! Since everybody is doing stuff for amlogic, i though in giving H6 boxes some love :) Many thks to gearbest for sending me the device to play :) Many Thks to my beta testers trebor READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!! THE SDK USED TO BUILD THIS ROM... IT WAS
don't know why it cannot work with 9.0
Originally posted by thuongshoo View PostJust sharing my experience :
- both android 7 and 9 are not good. Cpu is too hot so box is hang after a few minutes
- for Android 9, only 20190320 supports wifi but cpu also is too hot with this version.
- first flashing 20190218 from the website, then use the update application to get the latest version 20190508. This version is usable because cpu is cool, applications can respond to my requests quickly. This version doesn't support Wi-Fi because Wi-Fi MAC address is 02:00:00:00:00. Hope this issue is fixed in the near future .
- to flashing, just download and install the Phoenix suite frome Tanix' website. On the website, click tab firmware, then choose your .img file. Remember click the checkbox "download... then click all items to install all partitions. Then remove all attached cable from your TX6 box. While you're holding the power button, insert the USB cable into TX6, then firmware is flashed automatically. The phoenix software will ask you that you want to "incremental upgrade " or "format upgrade", I always choose "format upgrade".
- After the Phoenix finished, remove the USB cable from TX6 because the cable cannot supply enough power for TX6. Now you have to insert the power cable into TX6.
Thanks for all your feedback. I just sign up just to share my info with u guys.
I have Star Tech (clone version of Tanix TX6. The specs are all the same). Last time i used to have crackling sound and i tried many ways. One of it is i reset the android tv box from the settings, after that i didn't have crackling sound at all. I ran the box for like 4 hrs and the temp seems kinda normal not too hot (i just feel it on the surface). I did that for both the Star Tech boxes and it work until i reset again 1 of the box again and the crackling came back.
Back to square one i started googling for some info and came across another group Tanix Tx6 in facebook. Few of them had the same issue as me and one of the suggest that when the cracking sound comes back just mute it and unmute back. Below is the post that i found in fb. Thank you.
"I would remove the download link until you resolve the sdk issues. I have been working extensively to fix the issue. When the volume is crackling you can press mute and unmute and its gone, it FOR SURE is sdk issue with the audio drivers, I think its crazy this download link is still up with the amount of sdk issues you are facing. Crazy"
Star Tech Spec:
Allwinner H6, up to 1.5Ghz, Quad core ARM Cortex-A53
Mali-T720
Build in bluetooth
4GB
32GB
DC 5V / 2A
Android 7
Model H6
There are currently 3364 users online. 2 members and 3362 guests.
