9 times out 10 the problem is going to be with 1) your router's configuration,2) it's location or 3) the radiation pattern of it's antenna(s)
Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by LITO89 View Post
9 times out 10 the problem is going to be with 1) your router's configuration,2) it's location or 3) the radiation pattern of it's antenna(s)Last edited by c,lei; 22 June 2019, 22:03.
Originally posted by Hikvision View Post
I have this firmware installed.
Not worse and not better than 0506-0507
keep in mind that these three softwares have a different OTA update address
Originally posted by Hikvision View PostYour new firmware is on the forum since 15.06, with a warning !!!
Yes, I did see you posted firmware 06-15-2019 but you also said for 2GB/16GB device. Why I never tested it and I believed you got from 4pda website. So with finding this AndroidpcTV version the website said for 4GB/32GB and MIMO Wifi, that this would be different version, and the correct version for our device.
Also, ChinaGadgetsReview.com has TX6 firmware posted with date 20190615, which is probably same as that AndroidPcTv.com
Originally posted by RiCkLaR_atvX View Post
You are using the correct Reset button? The button on the side, seen through the grill venting? Not the button on the rear, which is for for dual-booting Linux from SDcard/USB.
Because it is hard to hit straight-on the side button reset, button is squarely behind a vent slat, it does take a few pushes of the button at an angle to get it to reset and burn firmware. Best solution I can offer you to try is the windows PhoenixUSB Tool from Beelink for Allwinner devices, read back several pages I upload the link to the firmware Tool from Beelink and can also find it in Beelink GS1 topic on FreakTab. That USB Tool has never let me down, unlike the PhoenixSuite Tool which can be hit and miss.
none of the sdcard, phoenixsuit and usb pro does not work, the device just works on and off with the android installed on the sdcard.
Originally posted by atillabattal View PostWith the reset button next to the phoneixsuit tool I've installed the software repeatedly, no problem. After the last software installation, the tool is gone. After that, phoneixsuit does not install the software in any way. The software does not load with the SDcard method.
If you read carefully my first post, it says use "Phoenix USB Tool" - if you have to completely uninstall PhoenixSuite then do so and continue only with PhoenixUSB Tool (not Suite). The Tool is simple, open Tool, load firmware image, click start, then connect with USB-to-USB cable and at same time pressing reset button during cable connection. Firmware should start Burning a few seconds after connection, may have to hold reset button for 5 seconds then let go, or press reset and hold button a second time for connection to establish.
Hi I also had trouble with tx6 ,with all softwares and manuals for flashing device ,I only get boot on display and nothing more , boot on display may stay hours ,try with usb stick ,SD card ,usb cable ,I afraid is not software issue I think is something with hardware, what to try ? Device cannot turn on and only when try to flashing TV detect signal through hdmi but is only full blackLast edited by Gogi777; 26 June 2019, 10:08.
I picked up a TX6 off of Amazon seller called Pendoo. It had Pendoo branded software on it, so I flashed firmware from Tanix.
No usb A to A cable yet, so I used PhoenixCard and put the software on a microSD card.
No issues at all, no reset button needed. Simply inserted the card and turned it on.
Flashed 0228, then OTA updates 0325, 0401, 0418, 0508 were installed.
There are currently 4179 users online. 1 members and 4178 guests.
