Is UHD / 4K?
[ROM] Beelink GT1 Mini OREO SCV3-ATV ( AndroidTV 8.1 - S905x2 )
Hello superceleron,
first of all, thank you for your work, everything seems to be running alright. I have even managed to flash both boxes on first try
I'm mainly using android TV with KODI, which is 100% working. However, another box will be used as IPTV device by my relatives. I have encountered issue with application from IPTV provider. I'm periodically getting errors "Failed to post notification on channel "null" ". I have thought that it doesn't matter, but after few cases, remote froze and i had to force close whole app. Do you think it could be fixed somehow? App is SledovaniTV.
BRLast edited by Dundee64; 07 January 2019, 14:17.
BR
About the problem you say, i have a feeling i know what it is, in a next update i will add some stuff to see if it fixes it
Great work superceleron
Flashed the DOWNLOAD HERE THE SCV1-ATV IMG for Beelink GT1 Mini. to my T95Q
Very easy flash 3.15min to finish the burn
WIFI and Bluetooth both work
Nice to see both top and bottom bars
Fast clean rom
CEC works for meLast edited by blinkone; 08 January 2019, 15:58.Please consider making a Donation to freakTab
Hi, can someone help me.. i have x96max and device is similar spec with beelink.. somebody said its compatible, so i downloaded the rom (scv2 ota), put is usb drive and flash the rom through recovery..
now stuck at boot logo as per pic below.. can somebody help me to get me to stock firmware.. i know this is my mistake for using another device firmware.. but if u know the solution, please help...You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by omaramiromo View PostHi, can someone help me.. i have x96max and device is similar spec with beelink.. somebody said its compatible, so i downloaded the rom (scv2 ota), put is usb drive and flash the rom through recovery..
Originally posted by ozzman666 View Post
I installed it to my X96 Max 4gb/32gb model today and everything seems to be working great from the things I tested. I believe your issue may be because you tried to install the SCV2 OTA update before first burning the SCV1-ATV IMG file with the USB burning tool.
I firstly tried the OTA update but it failed and gave back
E:signature verification failed
E:error: 21
Installation aborted
And leaves me at recovery screen
I then tried the burning tool many times both using usb2 and usb3 port but update never starts (box is just booting to stock rom when I plug usb cable and gets power). Drivers are installed properly according to windows.
Any ideas whats going wrong?Last edited by stavkon; 13 January 2019, 02:25.
There are currently 1452 users online. 0 members and 1452 guests.
