[ROM] Beelink GT1 Mini OREO SCV3-ATV ( AndroidTV 8.1 - S905x2 )
I've been flashing on the T95Q.
It is very good.
But there are two problems.
1. The remote control does not work.
How do I enable the remote control?
2. The LED does not turn off even when the power is turned off.
How do I turn off the LED when the power is off?
Please let me know. Thank you.
Hi guys,
i'm new, and i just received a gt1 mini box
what is the best rom? this or " [ROM] Beelink GT1 Mini TVStock Nexus ROM (Android TV 8.1)"?
i don't understand the differences...they both are android tv 8.1...what do you suggest?
Bravo superceleron great job!!
Reflash TV Box X10 Pro s905x2 4/32 Gb. There is a problem. Remote does not work and display.
There are ways to solve this problem?
Thank you in advance
Have this rom on a T95Q, it seems much faster and peppy, Is there a way to make a flashable zip with the remote control commands in it, or just enough to be able to turn the box on without unplug/replugging it? I can't find an app to open the .img of the stock rom, but did find some remote files in the root directory on the stock rom I had on it before. I also found the LED files but I can live without the light thing. tia.
superceleron
Could you please tell what's the trick for this? (will save me searching)
Enabled Amlogic H264 2k / 4k HW playback ( ye it was disabled... )
Thanks.
Thank you for the ROM, as much appreciated as the one you made for Alfawise S92,
While my S92 is still able to install apps from Playstore and the stock GT1 mini was also able to install apps, is it normal that I cannot install my apps with this new SC ROM?
As I read from Wikipedia ?Android TV supports software from Google Play Store, including media apps and games.?
In the box playstore, they just don't show and from my PC or Phone, it says they are not compatible with the Beelink GT1...
I do understand Google's idea in developping Android TV but unless there is a bug in the ROM or I am missing something, this ROM while nice and fast has now limited my box capabilities...
Any help?
superceleronLast edited by NinthWave; 24 March 2019, 14:57.
There are currently 1492 users online. 0 members and 1492 guests.
