[ROM] Beelink GT1 Mini OREO SCV3-ATV ( AndroidTV 8.1 - S905x2 )
superceleron
would this be suitable be flash into MXQ G12 running on u211 on android 8.1?
Cheers mate!
Originally posted by Appdata View PostHave this rom on a T95Q, it seems much faster and peppy, Is there a way to make a flashable zip with the remote control commands in it, or just enough to be able to turn the box on without unplug/replugging it? I can't find an app to open the .img of the stock rom, but did find some remote files in the root directory on the stock rom I had on it before. I also found the LED files but I can live without the light thing. tia.
The off button has changed to volume - .. with that button you can turn off the t95q. what are the led files? ..
if you want the remote work for you, you must install rom for x96max.
Originally posted by Atlas_co View Post
You can unpack any amlogic rom .img with amlogic burning tools modify and repack it.
Originally posted by Shiko View PostHDMI CEC works. It does not work with the cable that comes with the device. If you change the cable, the device turns on and off TVs that support HDMI CEC.
There are currently 1433 users online. 0 members and 1433 guests.
