[ROM] Beelink GT1 Mini OREO SCV3-ATV ( AndroidTV 8.1 - S905x2 )
The rom boots up on my h96 max x2 but due to non availability of Wifi drivers, I cant move forward. But it does work and my mouse works too. All the roms seem to boot up fine, the ones which are ATV cant go forward from initial setup because of no wifi and the non atv roms boot fully but no wifi ethernet. If I unpack the rom and add wifi folder from vendor/etc of stock rom wil it work?
My reset/recovery button on X96 Max doesn't work. How to flash new ROM without it? Amlogic_s905x2_setup_v2.1.6.8 Burning Tool cannot detect my box at all. Also, I can't enter TWRP bcs my box is stuck on boot logo...
Originally posted by megamuzzy View PostPlease make OTA version to upgrade from SCV2 to SCV3 while saving the stuff... Thanks!
Originally posted by merinns View PostMy reset/recovery button on X96 Max doesn't work. How to flash new ROM without it? Amlogic_s905x2_setup_v2.1.6.8 Burning Tool cannot detect my box at all. Also, I can't enter TWRP bcs my box is stuck on boot logo...
Ok, I did it, my X96 MAX 4G/64G with SCV3 works great. After press START in Burning Tool, I connected USB M/M cable in USB2 port on Windows 10 PC and USB3 port on Android Box, power cable was unplugged. Process took three and a half minutes. Thats it
Originally posted by Charlie_Boy View Post
How many external HDD's can you use via USB? The stock firmware on the X96 Max 4/64 can only mount 2.
Originally posted by kenduvernay View Post
The USB ports on all the 905x2 devices seem to be borked! T95Q, plug in a storage device and the box reboots. USB remote air mouse, only works half the time.
I am starting to think that the best thing to do is source a 905x2 box that is supported by OpenElec or LibreElec and get that.
A lot of people are dissing these cheap 905x2 boxes and whilst I understand their disappointment in the software I have to say that the hardware chews up and spits out any movie I play on it of any size. Minix in comparison is poor with large files. The 905x2 is a beast and a very powerful one.Last edited by Charlie_Boy; 26 January 2019, 13:28.
Hi guys. I have a T95q box how do I flash this rom without a pc? Do I just download the zip in the first page and open the update and backup app and find the zip on my box or do I have to use an sd card? Can someone post exact detailed instructions as ive never done this before and don't want to brick the box thanks
I successfully flashed SCV3 to X96Max 4/64 with sd card method (burncard maker). All working nicely with the following notes:
1. Remote controller not working
2. Bottom menu is only showing once at the first run after flashing, and its gone forever.
3. Dual wifi, I havent check this.
4. No root access
5. Enter burron in the keyboard (logitech mk240) dead (dont do anything).
However I really need that bottom menu and enter button, but now I am stuck to revert back to my original firmware that allow me to tweak some of the issues.
Either SDCard and Usb method is not working. The unit will never enter the bootloader screen with reset button + power.
Any help would be appreciated.
Javen.
4. No root access
Javen.
1. Install Amlogic burning tool 2.1.6.8
2. Download any u211 ROM you want to use
3. Run Burning tool as Administrator
4. Load ROM to Burning tool
5. Connect M/M USB cable to USB 2.0 port on PC
6. Press Start button in Burning tool
7. Connect M/M USB cable to USB 3.0 on Android Box (I never connect power cable and it works perfect without it)
8. Wait 4 minutes until process ends
9. Press Stop in Burning tool
10. Thats it
There are currently 2398 users online. 2 members and 2396 guests.
