I'm not sure why the drag-up navigation bar stops working in Android TV, though, and will investigate. I might be able to tweak some code there to re-enable it.
[ROM] Beelink GT1 Mini TVStock Nexus ROM (Android TV 8.1)
Guest
Hey Magendanz please help,
I want to buy me a new box but i am not sure the
T95Q
Beelink GT1 mini
Mecool KM9
Mi Box 3 or 4
Fire TV Stick 4K
I have no idea yet please your opinion... (70$ max)
Chromecast or Miracast is must have and android tv is better to have.Last edited by yanardag; 19 January 2019, 16:39.
I flashed this on a T95Q, everything is fine but the remote has stopped working. Is there anyway I can back up my remote.conf from original and transfer it over to this rom?
Great work btw.
The Amlogic SDK for Nougat and later has the remote codes hardcoded into the device tree (dtb). Probably the easiest workaround is to swap the _aml_dtb.PARTITION from your original T95Q firmware.
The Shiningworth firmware on Nougat made the effort to revert back to the old remote.conf system, which made things much easier. However, I haven't seen one based on Oreo yet.
T95Q
Beelink GT1 mini
Mecool KM9
Mi Box 3 or 4
Fire TV Stick 4K
Hello sir,
I tried your rom on my h96 max x2 device. The rom boots up and after 5 minutes of Nexus logo, it reaches remote pairing and then language selection, proceeding to network, it shows connect to wps but doesn't detect my network, wifi or ethernet. So the rom seems to be working but there is no option to skip network and move forward. I understand this rom is not built for my device so it doesn't have wifi mac license keys. My question is can I port your rom for my device for personal use? If yes, is there a guide to rom porting because I cant find anything apart from mobile rom porting guides.
flashed this on my X96 MAX 4/64GB version, working perfectly except one thing, auto frame rate switching
first i installed spmc but it crashes when i try to play any video format (x264 or x265) after that i tried kodi, it seems it's working great, plays everything just i don't have auto frame rate switching option in android
is this feature implemented in this rom? or is there any possibility to enable it?
thank you very much
There are currently 3570 users online. 1 members and 3569 guests.
