[ROM] Beelink GT1 Mini TVStock Nexus ROM (Android TV 8.1)
Hello Magendanz! Thank you for your hard work I am using this rom on x96max 4/64 s905x2. I like this rom, it is beautiful and easy to use, but there are still a few errors if it can be solved. Error 1: The box led indicator is not on Mistake 2: The box comes with an infrared remote control that cannot be used, only with a remote control with a USB receiver Error 3: The input method cannot be used. When I first entered the system, I was stuck with wifi, and I could not enter the password. I had to connect the wired network to skip the wifi setting and enter the system. After entering the system, change the input method to connect to wifi Error 4: After the wifi is connected, it is confirmed that there is a network, but the system keeps prompting that there is no network connection Mistake 5: There is a custom shortcut startup, that is, the file collection does not have all the app options I installed, only individual apps The above is translated from Chinese into English by Google, I hope you can understand
#64.1Guest commented16 February 2020, 08:10Editing a commentAlmost all of the issues you listed above are due to the fact that this custom ROM was designed for another device, one that has no LED, a different IR remote, and a different wireless chipset. So, these issues are really to be expected. I would encourage you to develop a custom ROM of your own for the X96Max.
Thank you for your reply, if you use this rom in gt1 mini, is there any hdmi cec setting? Can a custom collection choose a specific app from all the apps you install? If all is ok, I can buy a gt1 mini for use. Would you like to ask if you are interested in making 8.1rom for gt1 mini2 s905x3?
Thank you Magendanz.
I love your ROM! It's clean and fast.Good job!
Is there a pie on gt1 mini possible?Last edited by ChenYimin20021122; 30 July 2020, 15:03.
There are currently 1502 users online. 1 members and 1501 guests.
