And please dont be sorry. Most of us are noobs here except thread starters, its on us that corporations earn. We form their bread and butter.
[ROM] Beelink GT1 Mini TVStock Nexus ROM (Android TV 8.1)
I ordered usb m-m from **** but cannot wait to try this firmware, and I was so stupid that thought the OTA is same with usb burning. So I used OTA to flashed this firmware and my X96 Max cannot start and even enter recovery. I tried every method and even to short circuit HDMI and also the points from Russian forum, but the usb connection to PC still drops after 3 seconds.
Do you happen to know how to save my box?
thx MAG,could you tell me if i can use my voice control remote to search in youtube with you firmware,as the factory rom does not support searching youtube with remote .i hope i will get a positive answer.
You'd have to add the kernel module for that tuner. I'd scavenge around the nVidia Shield TV firmware releases (https://developer.nvidia.com/gameworksdownload) to see if it's there. Then you just need to add the .ko file to /vendor/lib/modules/ and then call insmod for it in /vendor/ext/init/hw/init.amlogic.board.rc.
Try it manually first, though, since these kernel modules tend to be very temperamental. If the kernel is missing some expected symbols, it won't install.
Magendanz- Yes i can myself confirm youtube play videos 4k 80/140 mbs I'm impressed. I want know if mecool km9 rom it is compatible with this beelink. If there was a way ,because mecool km9 has L1 and hdcp?
Originally posted by kuzzman View PostMagendanz, look this: https://4pda.ru/forum/index.php?s=&s...ost&p=82682579:
https://forum.freaktab.com/forum/tv-...d-other-clones
Originally posted by blinkone View PostGreat work Guest
Flashed theTVStock Variant:BURN PACKAGE to my T95Q
Easy to flash, took 4.48sec to finish the burn
Everything is working great
Wifi and Bluetooth work
Nice clean fast rom with no crap
I would of liked to seen both top and bottom bars in the rom too but no big deal breaker
Originally posted by ojerez View Post
How did you manage to pair the remote? Pulse back and Home but do nothing. Thank youPlease consider making a Donation to freakTab
There are currently 2420 users online. 2 members and 2418 guests.
