A doubt. I have the T95Q 4/64 gb, 10/100/1000 and a Mecool KM9 Android TV with control with microphone and 4/32 GB and 10/100. Which one would you stay with?
[ROM] Beelink GT1 Mini TVStock Nexus ROM (Android TV 8.1)
Hello, install the rom in my t95q and it seems that everything works fine, but I see some bugs ..
- the led does not change color, and continue on with the t95q off
- Netflix application does not work, I tried a couple of versions
-doesnt plays videos the prime video app
- the remote control does not work, I have changed some files and only a couple of keys work
How can I turn off the LED when it is off?
And how can I make Netflix work?
Can I set up the remote control in some way?
#48.1Guest commented08 March 2019, 00:12Editing a commentThis was built for the GT1 Mini, which doesn't have a programmable LED. Netflix won't work because these devices don't have Widevine L1 and aren't whitelisted by Netflix. Amazon Prime Video won't work because these devices don't have the required PlayReady DRM.
first of all, congratulations for the rom, good job and thanks for answering.
I suppose it is complicated to solve the bugs that this rom has in the t95q (remote control and LED lights) .. but, I wonder, ...
it would be very complicated to modify the original rom of the t95q with launcher android tv and all google tv ecosystem ??
Originally posted by Atlas_co View Postit would be great if you did it in t95q, .. I offer to be your beta tester if you want to try it.
i have T95q box too and amazon prime and netflix working well...
if u dont like the stock launcher just install another one from playstore.
u can also install a notification and navigation bar from the store...
hi,i just received my t95q and i want to switch it to android tv.
I read your article and comments.
thank you for the this work
I am beginner, can someone explain step by step to realize this manipulation.
I just have to download the burn package, copy to a sd card and press reset box?
What is USB Burning Tool v2.1.6.8 or BootcardMaker v2.0.0.2 for?
thanks in advance and sorry for my beginner's questions and my english, i am french.
it's installed, everything looks good, thanksLast edited by franzzy44; 26 March 2019, 08:04.
Okay, Got this on a T95Q, everything seems to work, (have not tried wireless as I use ethernet).Stock remote, bluetooth remote, everything seems fine. I'm using the ATV launcher and uninstalled leanback. I have a question, not about this rom but about the device. It seems no matter what rom I use Plex spits out bad quality video. I set plex you use best quality, but it still looks like 360, 480 at best video, Am I missing something, or is it to do with these boxes? This thing works great except for the led light, but I can live without that. Thanks.
Originally posted by Appdata View PostOkay, Got this on a T95Q, everything seems to work, (have not tried wireless as I use ethernet).Stock remote, bluetooth remote, everything seems fine. I'm using the ATV launcher and uninstalled leanback. I have a question, not about this rom but about the device. It seems no matter what rom I use Plex spits out bad quality video. I set plex you use best quality, but it still looks like 360, 480 at best video, Am I missing something, or is it to do with these boxes? This thing works great except for the led light, but I can live without that. Thanks.
Hey boy .Firmware of Build number 002P0 (Android version 9.0) has been released.Can you make a new TVStock Nexus ROM?
There are currently 1824 users online. 0 members and 1824 guests.
