[ROM] Mecool KM9 TVStock Nexus ROM (Android TV 8.1)
Thanks for you work like always but... live channels and tvirl don't fitt well in display(previously set to 320dpi in build.prop), voice control not allowed and a lot of inconvence for that non-ATV properly firmware so... i appreciate a lot your work but for my daily use, i'm going back to 1122(0106)Last edited by taox; 18 January 2019, 05:09.
#16.1Guest commented18 January 2019, 01:26Editing a commentRemember, we at FreakTab guarantee our customers are completely satisfied or their money back!
I prefer the 240dpi because it works better with the non-ATV apps like the Chrome browser, but not everyone will agree. The beauty of TWRP is that you can easily edit the build.prop to change it back.
Originally posted by Magendanz View PostChangelog (20190117):- Based on latest OEM firmware (OPM1.171019.011 V0828.20181205)
- Latest build from Open GApps (20190117)
- Android TV Remote Control service will pair, but keeps dropping the connection.
- Google Cast Receiver broadcasts, but will not connect.
- TVStock Variant: BURN PACKAGE (1.69GB IMG file), OTA UPDATE (966MB ZIP file)
Originally posted by Magendanz View PostThis custom ROM adds support for some popular game controllers, uses the Lineage App Drawer (for non-ATV apps), exposes More Settings (non-ATV settings), bumps up the UI resolution, and strips more of the non-essential OEM apps out. Frankly, now that VideoStrong has switched over to Android TV and the TV Home Launcher, the differences aren't all that significant. It's really a matter of taste.
Streaming bugs probably won't be corrected with this custom ROM, as I didn't do any kernel work or update codecs/drivers.
Does this rom fix sleep bug ? In stock 1205 after some sleep time (hour or 2) the box turns the light blue but it's not on. Remote doesn't turn it on (i have regular remote).
Also i'm using mx3 air mouse and getting q instead of enter key. Works ok in Kodi. Any easy fix ?
Sleep behavior should be the same as for the 1205 OEM stock firmware. I didn't mess with that.
As for the Enter key, you need to check the active keyboard layout (.kl) file and ensure key 28 is mapped to ENTER. I fixed Generic.kl (on both system and vendor partitions), but your air mouse is probably mapping to a different file.
hi Guest thank you for your support. i use your roms a lot but i have problem on my km9. i run my box all day on last weeks and i get "insufficient space" error.
when i look to storage there was 30-40 mb left. i dont run any download apps like torrent or etc.
Does anyone know if this build would work in a S905X, 2/16gb box? Trying to see if I can activate an old box with this. Also, is the build rooted?
Hi trying to download Burn Package but I only get "processing Request" pretty same for Usb burning Tool, pls help
Sent from my Redmi 5 Plus using Tapatalk
P.s. it is working (it looks like chrome blocked download) but download speed is slow it looks like it won't download in few days it is going 6-7kbs
Can I speed up?
P.s.2 I downloaded it on second try with normal speed, but I have issue burning Tool didn't recognize any device, trying with male to make Usb 2.0 to 2.0
Cable is 1meter longLast edited by GoranTz; 23 February 2019, 11:11.
Originally posted by dangchui View PostHello Magendanz
you see on gearbest the new MECOOL KM9 android tv on website appear to have ANDROID 9 PIE VERSION ANDROID TV
Can you see if there s possiblity to have this rom
been running Android pie for 2x months. Got it from this form. It is buggy, youtube can play videos above 480p or you get the green screen.
I do see gearbest states its Google certified.....hmmm
How can we certify our boxos? As mine is not certified
There are currently 1506 users online. 0 members and 1506 guests.
