[ROM] Mecool KM9 TVStock Nexus ROM (Android TV 8.1)
Originally posted by uscool View Post
I flashed KM9 that came with Android 9 not sure whats franklin board , it worked wifi stopped working but i think thats more to hardware failure flashed back the stock and still same
Originally posted by kenduvernay View Post
What's that got to do with the question? The point was if ATV 8 would run on the box...
Although the WIFI worked the first time it stopped working but that is probably do with hardware fault
So yes KM9 that comes with Android 9 will work with the custom ATV on this thread
Hope this helps this time
I just bought one of the Sidiwen KM9 with Android 9.0 (https://www.amazon.com/dp/B07PXJD3T6..._-j4PCbQX8C8FX) and it's BUGGY as hell.
Here's some of the fun things you can expect it to do:
1. Randomly closes out of Kodi and returns to main screen.
2. The "Update" app returns an error"Check Failed!Check Your OTA Server Agent".
3. Sleep function does not work, when going to sleep the sleep light triggers, but shortly afterwards the light turns back to blue and the system becomes unresponsive. Requires a power cable pull.
4. Because it's Android 9.0 there are NOT very many apps compatible with it.
5. On the main screen one of the unremovable icons "TV Center" doesn't work.
And to top it all off, it says MECOOL underneath and on the splash screen when booting up lol.
I'll update as more are found but this thing has been a MASSIVE letdown and I JUST got it yesterday.Last edited by AgentJeffy; 05 April 2019, 20:05.
Originally posted by AgentJeffy View PostI just bought one of the Sidiwen KM9 with Android 9.0 (https://www.amazon.com/dp/B07PXJD3T6..._-j4PCbQX8C8FX) and it's BUGGY as hell.
ok, I'll do the burn package. Strange happening is, I have a ms8 pro w and i follow the same steps and resolted.
Thanks for your help.
Thanks Megadanz, great job. You help to make a serious tool from a toy.
I have installed your ROM on KM9, but I have an issue with this ROM. Maybe you can help me.
For some Channels (e.g. HBO) does my TV provider some checkings, and I am not able to watch them. The checkings are:- is device rooted?
- is the device in debug mode?
- is some unofficial ROM installed?
- is some app for RAM debugging installed?
The problem are items 3 and 4. Maybe item 2 also.
My questions for you are:- Is there a way to trick my TV software, so that it thinks it is official ROM version? (e.g. like hiding root from some apps)
- does some debug app run in background in your ROM?
- is there any other way to turn of debug mode?
As a rule I don't play these games trying to deceive apps into running by spoofing a different environment, since it's usually a losing battle. I'm sure there are tricks that might work for a time, but I'll leave that to others.
However, you can disable debugging (and all other developer features) in the Developer Options menu.
Hi, i have a KM9 with android 9.0 and it was very buggy and most apps from playstore could not be installed. So i wanted to try this ROM but i had some trouble getting my PC to recognize the device at first. I was booted into recovery and tried the "reboot to bootloader" option. Well now my KM9 is stuck in a boot loop... It seems just selecting that option crashed the bootloader?
- I tried wiping/factory restore, no effect.
- I finally got my PC to recognize the device and tried to flash this ROM with the usb burning tool but i get a diskinitial error at 7%
- i tried flashing from sdcard/usb but it just boots into the recovery without automatically flashing like its supposed to. I used the sd card maker tools from this forum and I tried fat32 and ntfs.
- recovery does not mount sdcard/usb when i try opening them. sd card errors with invalid argument and udisk just doesnt show any files.
Did i perma brick my box just by selecting "reboot to bootloader" ? Help much appreciated, thanks.
Remember these u211 and u212 reference board are incredibly finicky when it comes to USB cables, so I recommend you try one with a ferrite core and braided shielding. My old male-to-male Type A USB cable that had worked for years on other devices just allowed too much signal noise for the KM9.
Also, this is why I removed the Reboot to Bootloader option on my TWRP build.
I made an sdcard with this method:
- https://forum.freaktab.com/forum/tv-...upt-bootloader
and i selected the "erase bootloader" in the burning tool and i managed to flash this ROM successfully. Dont know if the sdcard even had any effect, it was probably just the erasing of bootloader that did the trick. Anyway works now, maybe we should warn future km9 users to stay away from "boot to bootloader" option
Hi Magedanz , my KM9 was working fine , it started overheating i took apart the box and the IC S905x2 was getting hot ,The box boots and work for less than a minute and then keeps restarting.
update:
i was doing some tests , i placed a piece of playdoug between the board and the case to push from the other side the board against the IC 905sx2 to the heatsink then i flippled the box and placed a small fan with a circular plastic rim to pull out the hot air , also hard wired the network to prevent wifi heating and seems to be working now , hope it solved fro other users
Hello Magendanz,
Fiesta, thank's for your rom and your work. I've two box with your rom (km9 and m8s).
i've problem on km9 with remonte, when i push continually down or up juste go one Time up or down, you understand ?
Edit : i've test with volume UP and down, same problem.
Thanks for helpLast edited by Fr3d0; 22 April 2019, 17:46.
No, i use stock firmware without problems for d?cember, i found the remote is very slow when i click.
Edit : i've test with old firmware it's okey, do you know the problem ?Last edited by Fr3d0; 23 April 2019, 10:48.
There are currently 1598 users online. 3 members and 1595 guests.
