[ROM] Mecool KM9 TVStock Nexus ROM (Android TV 8.1)
Originally posted by Javiersba1 View PostI tried to give it to "enable write access" but without success
Guys, i have installed this wonderfull rom to my x96 max and now i am stuck...
Cant move on, needs remote)press two buttons to move on and my remote doesn't support two buttons), and after flashing this rom i can't enter recovery, can't usb flash(it boots straight to the rom).
Tried also sd card recovery metod and still it boot's to rom.
Any suggestions? Thank you in advance
Originally posted by kobatz View PostGuys, i have installed this wonderfull rom to my x96 max and now i am stuck...
Also anyone know how to root this rom? I bought a couple of these boxes to test- they would be perfect if they had root for adaway and removal of system apps.
Hi. I tried to install that ROM by burning tool but it's stucked at 28%. Now device is not working. When i plug the power adapter the led is not turning on. But pc recognizes the device when i plug it with usb cable. Please help me...
Edit: I solved that by using a different usb hub.Last edited by srvngrc; 05 August 2019, 06:58.
Hi Magedanz, I have to say it once more, excellent work! Thank you!
I have two questions for You:
1. How do you emulate (or simulate) taping (or touching)? On my other Tv Box, Xiaomi Mini, I can not use air mouse as on MeCool KM9 with Your ROM. Some buttons in different apps simply do not react. What is the catch? Some driver, or some app?
2. I can not connect MeCool KM9 with computer via USB cable. It worked with "USB Burning Tool". Of course, I use ADB via WiFi, but for debugging I need USB cable.
There are currently 1507 users online. 0 members and 1507 guests.
