Another thing: is it possible to disable voice-commands? My mouse-remote does not support it and now i have to disable it for any app i use. Not too much of a problem, but maybe i am missing a setting?
[ROM] POISONATV S912 NEW V3 [20190307]
Can anyone provide me the LatinIME.apk ? I searched but can't find it or untrusted resources. I would like to add it to the image so i can disable onscreen keyboard totally.
Hi
First of all, congratulations on this awesome ROM.
My ethernet port is broken on my H96 Pro Plus 3Gb 16Gb DDR3 TV Box.
I am trying to use an Orico USB to Ethernet adapter as the WIFI is terrible on these boxes.
I could get it to work on all android 6 firmware, but not on Android 7 firmwares.
Is there a way to activate this in Android 7, or is it possible to add support for ethernet adapters?
Thanks in advance
neomode Thanks for this rom. It's very fast and playback movies is very smooth!
Just some things i missed:
On Android Remote App, the home button doesn't work, Beelink GT1 (2GB/16GB Serial number Gxxx) doesn't work too.
Play Store apps install not working
Is possible to cast to device just like chromecast?
Originally posted by jefferzombie View Postneomode Thanks for this rom. It's very fast and playback movies is very smooth!
You can use Airscreen to Cast to the Device.
What is your Problem with GT1?
Neomode
Neomode
Just the home button on remote. It's not working. On Android TV app is not working too.
I'm finish the setup right now. Later i will do 'real usage' and leave my impression.
jefferzombie did you figure out what was going on with the google store? i have the same problem with my gt1 ultimate !!!
Thanks in advance
Nope, I try to flash opengapps in the twrp but gives me a error. I flash magisk and stuck on 'poisonatv' screen.Originally posted by Glm47 View Postjefferzombie did you figure out what was going on with the google store? i have the same problem with my gt1 ultimate !!!
Originally posted by neomode View PostPlay Store should Work, I tested it on my box.
Give it some time to update.
Then retry please.
amazing work. thank you to everyone involved in the project
Originally posted by antonio6o6 View PostNeomode can you please help me out on my minix U9H on my control remote issue. I upgrated firmware V3 but I still have the issue with the remote control don't want to turn on my box on. Can you tell me which control will work on the firmware V3. So I can buy it.
Really the best you can get for your Money.
There are currently 2546 users online. 1 members and 2545 guests.
