[ROM] POISONATV S912 NEW V3 [20190307]
Originally posted by neomode View PostHere it is this added a lot of Drivers to the System, like USB Ethernet Touchscreen Joysticks etc.
https://file.freaktab.com/public/dri...tXPPpe63mXAlWS
Originally posted by minixfreak View Post
I'll update a patch soon ... also I made script to run from init.d ... my clock works fine it seems like a t95z model that is not working correctly ...
It seems I can't do nothing with this firmware V3.. USB Port not working on my Minix U9H and still have issue with Remote Control dont want to Power on the Box. When I change software to the original Minix Firmware USB Port Works and Control Works. Can Someone Help Me with this Issues with Firmware V3.
Originally posted by minixfreak View Posthttps://mega.nz/#F!c4RhHaAI!YD7VoFfZf616OP6qfqBu-Q
I fixed the issues in the build ... neomode will update thread soon but those are the links to the fixed builds
I have a Sunvell T95Z plus 2/16Gb
flashed with V3 Redpoison latest version.
Flashed the QC9377.zip
Flashed 4.1 Bluetoothfix.zip
no problems i can update google play store
flashed the T95Z_1 pro clock display failed to work BUT i did change the file in the .ZIP (system/etc/init.d/00OpenVFD to 99OpenVFD) and it worked thanks for the info Ico747
Rebooted into TWRP and flashed Magisk18.1 and the rebooted No problems then installed Magisk Manager 7 and all is well with the TV box
Also cod1 18.1 works i use juggernaut build others are available
now all is working for me have not tried the ethernet so i cannot say but everything else is working.
Many thanks for the teams hard work on making this ROM.
if only i could get amazon prime and SKY Go to work i would be set but heyho
Ethernet working as well
I am trying to port this Rom to m8s "plus" L. I followed this tutorial https://www.cnx-software.com/2016/08...x-s905-tv-box/ , box boots but I can't get passed "checking for updates". Can anyone guide me on doing a proper port of this Rom?
There are currently 1864 users online. 0 members and 1864 guests.
