[ROM] POISONATV S912 NEW V3 [20190307]
Thanks guys, Ricky Divjakovski, Whiteak, Minixfreak and Neomode.
I got running on my H96+ pro and T9 S912(sunvell alike).
Very responsive even I own 2gb ram on my T9.
Magisk worked, now my AstroGo app can run with popup jailbreak device detected.
Really a great ROM. I enjoyed it very much, apart from responsive, it also handle multiple apps in background much much better for my T9. I used get lagged when opened few apps like Kodi, file browser and movie app.
Only a minor recommendation suggested herefor next update if possible, volume for boot up could be lower a litte.
Great job team.
Appreciated.
I have flashed PoisonATV Version3 on my H960pro+ 3gb ram 32gb rom.
after 24hours of using it I can say it is an excellent ROM. Only bug I found is that the wireless signal is fluctuating and not finding 5G frequency.
My box is using QCA9377 wireless module and on BluePoison Rom I had a perfect steady signal and 5G frequency available. Can you look into it?
The rest work perfect and I think you guys did an awesome work.
My only request for next build would be advanced power menu with option to go into recovery.
Originally posted by GeorgeS View PostI have flashed PoisonATV Version3 on my H960pro+ 3gb ram 32gb rom.
thank you so much
yes you need only usb burning tool, male to male usb cable, and the v3 .img file to load.
open program, load image, connect box and press the reset button with a needle or a toothpick to start the procedure. after success unplug box. press stop for tool and you are ready. 1st boot will take some time (mine was around 4-5minutes)
Originally posted by GeorgeS View Postyes you need only usb burning tool, male to male usb cable, and the v3 .img file to load.
Put into device and use reset/needle procedure to let it flash.
I use it cause I don't have a PC handy where my device is connected and it works quite well....sometimes you have to retry a few times and some people advice to disconnect everything not needed for operation before flashing.....
Originally posted by neomode View PostYes and it will be finished today.
Then you can use a external Ethernet Adapter.
Neomode
Thank you so much!!!
There are currently 2683 users online. 0 members and 2683 guests.
