[ROM] POISONATV S912 NEW V3 [20190307]
Originally posted by minixfreak View Posthttps://mega.nz/#F!c4RhHaAI!YD7VoFfZf616OP6qfqBu-Q
I fixed the issues in the build ... neomode will update thread soon but those are the links to the fixed builds
Does this update perhaps include support for USB to ethernet adapters that I requested?
First of all, thank the poison team for their work.
My device is T95Z PLUS 2G/16G
I used the latest version of the firmware(20190311-PoisonATV_S912_Sunvell.img). I have encountered some problems.
1. My device LED clock does not work..
2. I flash in the latest Magisk, the device still has unroot..
3. When the firmware is boot, the startup screen sounds too loud. How can I turn it off?
4. Should I install that version of the firmware?S912? ..Sunvell? What is the difference between them?
Thanks for the work, good luck.
Originally posted by Nexus_ZA View Post
Oh okay thanks for the feedback minixfreak
Just for interests sake, how would you load a patch if you don't have the original remote and the reset button is broken?
minixfreak Some people here are reporting not working LED clock. I could help but I need root access....
Remote is not broken just need the correct remote.conf or usb burning tool ... also terminal emulator is installed so reboot recovery and ur back into recovery
Originally posted by Ico747 View Postminixfreak Some people here are reporting not working LED clock. I could help but I need root access....
Is the LED display total black or some rubbish is displayed. In the last case - make a photo.
Originally posted by jefferzombie View Postneomode Thanks for this rom. It's very fast and playback movies is very smooth!
Just some things i missed:
On Android Remote App, the home button doesn't work, Beelink GT1 (2GB/16GB Serial number Gxxx) doesn't work too.
Play Store apps install not working
Is possible to cast to device just like chromecast?
So thanks to minixfreak too!
Just the home button on remote. It's not working. On Android TV app is not working too.
I'm finish the setup right now. Later i will do 'real usage' and leave my impression.
Mine is a beelink GT1 with the simple remote (just a feal buttons, seems like a MI box cheap copycat). I try for some hours and not work. I had to press back button several times to go back to dashboard.Originally posted by ado0813 View Post
jefferzombie regarding home button issue, please try app, it will make home button working, but....double click home button cannot open recent app list.
There are currently 2555 users online. 1 members and 2554 guests.
