(ROM) AndroidTV_Project S912 V2 By Team Poison
soldiaz i installed aptoide.tv.apk
then i used the amazon prime (white icon) and installed it .
then added my account details and it works here in the UK.
i first tried the one from the TV apps already installed but for me it does not allow video to play so i uninstalled it and used the above method.
After just a halve day of use on my T95ZPLUS 2/16 I have absolutely nothing to complain about!
Install went problem free (I still use SD Card Maker) but had to unplug-plug power with AV-reset button holding almost 20 times but after that everything went very smooth.
All works great so far, but have to install and test some apps and put IPTV on the test-bench regarding hiccups.
GUI and icon is sharper (hi-res icons) and quicker acting on button pressed (after second reboot).
Snappy release, thank you Developers!!
i also got the bootloop on my sunvell T95Z plus 2/16Gb
first time all i did was add TV Boot then reboot into system
so i reflashed again and this time sideloaded tvboot then into recovery then added the patches and stuck at bootloop.
Now going back to V1 via TWRP
hope you get it sorted my friend as it look good
There are currently 3479 users online. 0 members and 3479 guests.
