(ROM) AndroidTV_Project S912 V2 By Team Poison
Originally posted by Dmitri51 View PostI'm using the A3 control and the standard control (ir-control). The minix doesn't react on serval buttons.
Ow.. By the way... Thanks for you quick reply.
Verstuurd vanaf mijn WAS-LX1A met Tapatalk
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0x40400001
work_mode = 0
repeat_enable = 1
repeat_delay = 130
repeat_peroid = 120
release_delay = 20
debug_enable = 1
fn_key_scancode = 0x47
left_key_scancode = 0x10
right_key_scancode = 0x11
up_key_scancode = 0x0b
down_key_scancode = 0x0e
ok_key_scancode = 0x0d
mouse_begin
0 0x10
1 0x11
2 0x0b
3 0x0e
mouse_end
key_begin
0x43 113 #MUTE
0x01 116
0x02 115
0x03 158
0x04 181
0x05 191
0x06 168
0x07 10
0x08 18
0x09 17
0x00 26
0x45 125 #MENU
0x42 115 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 116 #VOL+
0x17 114 #VOL-
0x0c 14 #DEL
0x4d 116 #Power
0x1a 102 #home
0x53 119 #media_pause
0x44 52 #period
0x1e 123 #MEDIA_NEXT
0x1f 122 #MEDIA_PREVIOUS
0xf1 140 #F10/factory_test
0x54 150 #setting
0x57 151 #PROG_YELLOW/EXPLORER
0x5b 152 #PROG_BLUE/MUSIC
0x5c 153 #ALLAPP
0x5d 154 #MEDIAPLAY
0x5e 159 #KODI
0x66 217 #SEARCHSEARCH
key_end
repeat_key_begin
0x43 113 #MUTE
0x01 2 #No.1
0x02 3 #No.2
0x03 4 #No.3
0x04 5 #No.4
0x05 6 #No.5
0x06 7 #No.6
0x07 8 #No.7
0x08 9 #No.8
0x09 10 #No.9
0x00 11 #N0.0
0x45 125 #MENU
0x42 1 #BACK/EXIT
0x0d 97 #ENTER/OK
0x10 105 #LEFT
0x0b 103 #UP
0x0e 108 #DOWN
0x11 106 #RIGHT
0x18 116 #VOL+
0x17 114 #VOL-
0x0c 14 #DEL
0x4d 116 #Power
0x1a 102 #home
0x44 52 #period
0x1e 120 #MEDIA_FAST_FORWARD
0x1f 121 #MEDIA_REWIND
0x54 150 #setting
0x5c 153 #ALLAPP
0x5d 154 #MEDIAPLAY
0x5e 159 #KODI
repeat_key_end
Originally posted by minixfreak View PostAndroidTV Project
ChangeLog
-Based Off My PoisonATV Versions
-Improved stability and performance
-Brand New Look
-New Tweaks
-Amazing Video Quality
-First Boot might be a bit sluggish due to my new tweaks but after apps update and tweaks are done running you can do a reboot and second boot will be fast and pleasant...
-Always Use force erase all or erase all option in Usb Burning tool
-also for people on 4pda i see your using my work at least give credits or maybe developers from there could consider joining us
Download links
https://mega.nz/#F!IlxQmYKb!j51RvSawPtKxhV5yKhWbNQ
Hello, is it possible to send some screenshots of what your new tv system looks like
Nice version but still in "beta".
Does not store HDMI CEC setting. For example I set "HDMI CEC->One key power off" to "ON". After next start it is reset to "OFF"
Very long time before all scrips in /syste/etc/init.d ar done.
From time to time black screen for 1-3 seconds.
I hope it will be fixed in feature releases.
Hello,
Great ROM, this is the first android tv rom for beelink gt1 that allows me to watch video with subtitles at 24fps under kodi 18.
But, i can't use blokada. I noticed that vpndialogs were missing. But even if i install vpndialogs.apk, blokada still does't work.
Also i have error 'position independent executable (PIE) are supported' with zipalign and openvpn. But i don't know if it is related.
Can someone help me ?
Update:
I found. This is due to ipv6 blocking.
blokada work if you delete /system/bin/Disable_IPv6.shLast edited by nic029; 11 May 2019, 12:39.
There are currently 2292 users online. 1 members and 2291 guests.
