(ROM) AndroidTV_Project S912 V2 By Team Poison
Originally posted by soldiaz View PostDid you try same as attached?? [ATTACH]n775395[/ATTACH]
1. I downgraded Magic to the 18.1
2. I flashed the TWRP 3.2.xx from the Poison Rom link here.
3. Re flashed the X92 Clock fix .zip and .. wallah! Working
How can I use the TWRP 3.2 on a USB stick when pressing the reset button and booting from USB? Do I simply copy the recovery.img over to it? I was using a zip file that I would run from the stock android boot loader to get into TWRP before, but that was an older 3.0.xx version.Last edited by xbones; 11 June 2019, 00:20.
Hi I have a H96 Pro+ 4K Android box and I am exploring which ATV experience Rom to install.
This looks like a very nice Build..Thank you to the creator and his support team for all there work.
My board details and images below, BLUE PCB , S-32 V6 (LPDDR3) 2017-09-05 CZ 3G+32G+9377
Please can you tell me if this image (S912_LPDDR) from the link https://mega.nz/#F!5o5B0SII!p-W0crI8UbegQNA80vKSzQ is the latest version and compatible with my BLUE PCB revision and if so ?
I Burn this image with USB_Burning_Tool_v2.1.6 ( Force erase all or erase all option ) .Wait for it do do ALL it`s loading and stuff .Do I then just patch the image (Via TWRP Install zips option) with the patches 4.1Bluetooth_FIX.zip & QC9377_BT_Fix.zip from the patches.zip file. ?
Hopefully that is the correct procedure.?
Thank you all for any feedback, Help & Support.
Best Regards,
Guest
polosolo , no harm in trying, you can always go back to stock FW.
... I Burn this image with USB_Burning_Tool_v2.1.6 ( Force erase all or erase all option ) ...
Latest Amlogic Burning Tool v 2.1.7.1 available for download here.
... Wait for it do do ALL it`s loading and stuff .Do I then just patch the image (Via TWRP Install zips option) ...
@mAtvXk Thank you Sir for your support and help.
Thanks also for the updated USB Burning tool....I did not know it had been updated.
One more question Please before I proceed.....
In USB_Burning_Tool_v2.1.7.1 options Do I Tick or un-tick The erase boot-loader option in USB burning tool . ?
Checked or unchecked ?
Thank you for your Support and Help.
Best Regards,
Guest
Originally posted by mAtvXk View Post
There are currently 3427 users online. 1 members and 3426 guests.
