Does this update suite to any X92 device? LPDDR, DDR4 and so one...
(ROM) AndroidTV_Project S912 V2 By Team Poison
Thanks for quick reply!
Maybe my question was not close enough: the zip contains a dtb.img. As I can see it replaces the old one during flash process. Not to forget a service is being integrated..
Does this new dtb.img suit to any X92 Minix rom release? Since there are different versions relating to RAM (LPDDR...noLPDDR..)...
As i'm new to this i might ask a question that to all of you seems to be to obvious, so don't be to harsh on me :-)
I loaded the latest ROM on my stick and it runs smooth but the WiFi is unstable. Now i saw the patch for WiFi but really have no clue how to install this zip file onto the stick with the latest ROM?
Some guidance would be great. Thanks in advance.
--------------- Update, Sorry i asked, found the answer simply by using google, could have tried that before asking :-) ------------------
Originally posted by xbones View PostCan someone post a link to this ROM with all the fix'ns? I have an X92 and desperate for a modern good custom ROM.
The mega link is broke and doesn't contain the file.. ANYONE PLEASE HELP
Originally posted by antonio6o6 View Post
I used chrome and worked like a charm, apologize for the hassle.
Thanks you!!!
So couple questions....I have X92 and one of those TV air mouse remotes with a mic button and keyboard on the back..
1. I used TWRP and installed the x92 lcd zip fix.. Still no lcd.. I know I have to do something to enable custom vfd file or whatever. edit the mtd or something someone said while back.. I don't understand.
2. When using my air mouse tv remote, if I click ok to enter letters on the TV screen keyboard, it wont register the OK. (Ok button works when on main menu) If I switch to NON mouse mode, as soon as I select a letter on the TV Keyboard, then the keyboard disappears. My included X92 remote works just fine though.. But never had this issue with any previous S912 builds before using the ATV versions. Appears just might be the type of keyboard ATV uses? (I can also type with the keyboard letters on the back of my remote
Thanks!Last edited by xbones; 10 June 2019, 08:28.
There are currently 3396 users online. 1 members and 3395 guests.
