I have an imaged called S912_AndroidTV_V2.img, i think it is based on poison.
(ROM) AndroidTV_Project S912 V2 By Team Poison
Guest
Originally posted by Jimmyneutron View Post... a link to download the file for mecool bb2 pro which run on s912. Also whether it supports 9 oreo or i should just hang on on to nougat ...
hi all just wanted to say i love this rom but did not like the look of the launcher so i made some simple edits and came up with my style i like.
i done this to the 4.3 poison image on a t95z plus 2/16GB.
if anyone else likes it you are welcome to the image with the edits done...
i also added youtube android tv app to it and adaway and plex...i also changed the key map to work with universal usb remotes aswell as the original remote.
the image is not a backup its a fresh install...so u will need android 7.12 with twp installed then install this poison image as a install through twrp.
must say a big thank you to Ricky Divjakovski for creating the poison image its awsome.
here some screenshots of the launcher hope u like..but once again they was simple edits so dont slate me lol.
hers the 4.3 poison image to install with twrp if anyone wants to try it.
Originally posted by antonio6o6 View Post
If you want to give it a try this firmware 4.9 modify just make sure it's compatible with with your box. I tried a free VPN and it's working
https://mega.nz/#F!YAQg3CQY!A45M3cBz7hNrTpaxz7MA4g
Edit - never mind - found this thread - https://forum.freaktab.com/forum/tv-...-final-9-20-19
Is this the best choice for a Minix U9-h?
Is the appropriate image for U9-h in Minixfreak_OS simply the S912.img (i.e. not 1G or LPDDR?)
Is it possible to create a bootable SD Card with these images for trial, without committing to NAND right off the bat?Last edited by DEcosse; 21 February 2020, 21:12.
There are currently 2932 users online. 1 members and 2931 guests.
