(ROM) Minixfreak_OS S912 May25/2019 ""NEW""
Originally posted by xmannamviet View Post
installed magisk 19.2 but cannot hide root this rom??? and can't unroot, so what solution do you have?
Hi there MinixFreak, just wish to give you some feedback on your latest Rom that unfortunately, I was unable to use.
I've never had an issue using any of ur Roms but this new one starts to update but only for about 5 sec before the big red X over the android icon.
Adding to my disappointment I was also not able to go back to the build I was on as the mega account now had your latest build or I've lost the link?
While trying to get a Rom on the Device I did notice that atvXperience_S912_V2H_ Mod Sleep Mode Video improvement made my box show up a green screen nothing else
and I was finally able to get a Rom back on the device but one I've not used for some time due to your own work - S912_atvXperience_v2FF Normal (Aida64 Show it as S905X)
Anyone got any thoughts why one is working yet others not but there all S912.img Normal not LP
I was using Burn Card Maker as Device is a no show on USB to USB
The device is Beelink GT1 2/16 Soc S912
Yeah, I've finally Cracked it and got the New MinixFreak Rom installed!!
For those that get stuck here is what I did,- Reinstalled USB_Burning_Tool 2.1.6 (during install it says its 2.1.7 and in the about section, it says 2.1.3 Strange)
- Run it with Administrator rights (i could here it connect to pc but not see a connection until I did this)
- Load your image - http://tiny.cc/MinixFreak-OS-S912
- Connect you the USB cable to box and then pc
- Select your option - I chose normal erase
- This next step was key to getting it to work and stop issuing me were error - Romcode etc.
- CONNECT the Power cable to the device
- Then click start and fingers crossed it will finish 4 mins later
- When successful show take the USB out of the pc before you press stop as recommended (unsure why)
- Restart the Box and watch the Magic
The device was the Beelink GT1 S912 2/16
------ Installed the QC9377_BT_Fix.zip Patch if you have trouble with BT headset - http://tiny.cc/MinixFreak-OS-S912 ------ Thanks Neomode
Now I did try this using the Micro SD method but it gives error within seconds of upgrade screen and I also notice a few other Roms do not like this that method so hopefully moving forward this will fix the issue of some boxes not showing up when using USB Burning Tool
Hope this helps anyone that gets stuck like I was.
Now I just hope it's even easier when I get my new Box either the KM9 Pro or the T95Q ???Last edited by CcX85; 05 June 2019, 14:41.
There are currently 4703 users online. 4 members and 4699 guests.
