Krissy
(ROM) Minixfreak_OS S912 May25/2019 ""NEW""
Originally posted by antonio6o6 View Post
Krissy
Originally posted by mAtvXk View Post
Android TV App Launcher Builder
This tool creates banners for sideloaded apps that don't show up on the home screen.
I don`t want to add apps to the home screen OS display. which your linked app is for. The Home settings recommendations row is something totally different.
Best Regards,
Originally posted by Krissy View Post
Thanks, Antonio, going there now. Did want to mention something to you, on the ATV X forum you and bumerc, ricklar worked out some issues on that rom and the ports worked but it has much more serious issues than just the wifi. On Ethernet, it simply won't recognize a valid url for certain services and keeps kicking it out. That being said I just wanted to say that for a guy just learning this stuff I am super impressed with your dedication to what you're doing and the willingness to learn by making a mistake here and there and then correcting and moving. Man, when you get this stuff down you are going to be one hell of a Dev, keep up the great work, I see flashes of brilliance in your work. Just to be clear, I'm not a dev, I'm learning like you are, but don't have your dedication. Sometimes I screw up and I just say the hell with it, you are very different, and will in fact be a great Dev and a great addition to the community, but I have seen some of the great Devs both here and XDA so I can recognize talent when I see it. Keep up the great work my friend, I'm proud to know you.
Krissy
Thanks Krissy I start all over again with this firmware I got AVT Minix beta 2 Mod 2 Google Play Store working update.voice command on Google Play Store working did speed test direct to the moden accurate.working did Wi-Fi speed test working no issue . I tried touch VPN working. IPTV server working watching baseball for hours with no issue I'm going to post it on Sunday
Krissy
Guest
Originally posted by polosolo View Post...I want to add the apps to the recommendation ROW (Home Settings in OS) mate! This is in the home settings tab of the OS...
Google designed recommendations as an extension of an Android system most app developers already use: Android TV recommendations are actually just Android notifications! Clearly, one look at the Leanback Launcher makes it clear that recommendations are both more, and (in some ways) less, than 'normal' Android notifications. But they are created using the NotificationCompat.BigPictureStyle notification class, so they really are notifications with a bit of extra functionality. The key is that they are specially 'interpreted' by the Leanback Launcher as recommendation cards.
Originally posted by LeoM View PostThis rom work well on my H96 Pro Plus. But I still want to use the com.canzone.amllauncher or the SunvellWin8Launcher. I can install them but they don?t work on this rom. Anyone know how to make them work?
Fellas,
I have a T95Z Plus and 2/16 . Currently running in Poison 4.3. I saw the below 2 links from MinixFreak OS which appears to be a revised(later) version than Poison 4.3
Following are my questions:
1. Should i install/Upgrade S912_Revised.img or the S912.img in my ATV?
2. Any issues/concerns people had with upgrading to this latest ROM?
3. After upgrading , should i install the individual zip files as well from the patch folder(If yes, should i install these zip files using twrp individually)?
4. Is there a way i can find out if my ATV is running on LPDDR or the regular DDR?
I generally use Kodi, Typhoon, Youtube for Android, MX Player and Prime Videos in my ATV . I am newbie/novice in this area, sorry if i asked dump questions.
Thanks,
AkosettanLast edited by akosettan; 27 October 2019, 16:59.
What is the link of the most recent version? Use this on my H96 Pro + 3/32 https://mega.nz/#F!91IU0K5R!VvCOFtu1gagXyG09US3-Ig is there a new version?Last edited by WilliamBntz10; 29 October 2019, 01:54.
There are currently 2197 users online. 1 members and 2196 guests.
