(ROM) Minixfreak_OS S912 May25/2019 ""NEW""
Originally posted by Scotdog View Post
normy62 - that is correct, as antonio6o6 explained. The solution is to plug a USB hub into the OTG port of the U9 via the short female USB cable that came with your Minix. Thats the way I did it. Currently have my A3, thumb drive/stick and Rii mini keyboard all working. In addition, i have a 2nd Rii Mini keyboard that is bluetooth and it works as well. UTG is the only working USB with this firmware and if that's a deal killer, you'll have to search out another firmware. This rom runs well on my box and looks fantastic and worth the work around in my opinion. Thanks again antonio6o6 for the pics and videos. He explain the process very well.
Originally posted by antonio6o6 View Post
Thank you Scotdog for for making it more clear to explain. And Scotdog sd card slot on minix is working on minixfreak Firmware that's the way I set up my APK to the SD card slot. And thank you to help me out and splaning how is working remote control on minix u9h
Have a good weekend gentlemen!
I'm not sure man. minixfreak mentioned to others in this thread that he would use the S912 build for the two boxes I have. I guess he'll have to answer that one for you, or you could give them both a whirl and let us know. I've been curious too.
Originally posted by Scotdog View PostI'm not sure man. minixfreak mentioned to others in this thread that he would use the S912 build for the two boxes I have. I guess he'll have to answer that one for you, or you could give them both a whirl and let us know. I've been curious too.
Originally posted by soldiaz View Postthanks minixfreak . Didnt know there were S912 1GB manufactured...
Here is the remote configuration file for you Minix u9h. If you using mini freak firmware this is the one you need if you got the Minix u9h only copy and paste reboot the box. and you'll be good to go. My box u9 h Minix it's working great with that remote file I managed to turn on and off the Box use mouse key keyboard and I using a3 remote and remember you have to use C drive USB cable that came with the Box then you have to put the Bluetooth USB remote control in the sea drive to USB cable
https://mega.nz/#!dJwj0SpK!Mkpi9U6IK...OXbGngLd_Bwo6M
Originally posted by roleo55 View Post
Thanks for the link, I'm stuck on the select language screen. How do I add this file? I can't connect to usb burning tool anymore it keeps disconnecting after about 30 secs
There are currently 2519 users online. 2 members and 2517 guests.
