(ROM) Minixfreak_OS S912 May25/2019 ""NEW""
Originally posted by minixfreak View Post
might be because of h96+ ... Its truly differwnt box and has so much issues
Just asking for 100% confirmation that this is indeed the latest revision ? from this mega link .
The ROM even with the slight hanging issues ( TWRP & play-store installs) .....is by far and away the Best in the Breed , Thank you Sir for your Amazing work.
Best Regards,Last edited by polosolo; 26 August 2019, 18:01.
Originally posted by soldiaz View PostI guess there is a "REVISED" rom. But the one you picked is the best, yes
I think was original and I took the chance and installed this on the H96 PRO+ and everything runs very nice.... But a few glitchs with the TWRP and playstore install hanging and I am thinking should I try the revised image to see if it improved stability in this area ? Really not sure if it`s worth it? But I think I will .......as I just can`t stand not trying it ... ..........The what if scenario springs to mind .
I have a full backup of the image (TWRP) from the Box ATM ...So I might just do it , to see if it improves the performance in this area of the Box.....But I feel I have really been pushing my luck with this Box just now....as I have installed numerous varieties of the ATVX ROMS
( I Always return to a stock ROM before installing a new version which is very time consuming ) to find the Best one compatible with the H96 Pro+
Best Regards,Last edited by polosolo; 26 August 2019, 20:20.
So out of curiosity ...I instated the "REVISED" version. ( S912_LPDDR_REVISED) from this link https://mega.nz/#F!91IU0K5R!VvCOFtu1gagXyG09US3-Ig On the H96 Pro+
Everything went pretty smooth and Once it loaded I was pleasantly surprised... A very nice loading screen at the start and the OS itself is much superior to the other version I had used.
WHY OH WHY People............The Answer quite simply is.........Never a straight Answer.and with that...I had wasted a few days of p@issing around with previous older revisions which I had been led to believe
where the latest. What a f@@@king runaround ... lol
One thing is for sure though is the next person who does decide to install on a H96 PRO+ model with same spec as my box....Will now have the full undisclosed Facts and links to the correct Firmware ROM for that BOX.
The OS of the revised ROM is so much smother loading at startup and generally much sweeter and I have no problems with any updating lag ...unlike the other version.... also TWRP boots much smother and quicker, The actual interface back grounds and icon coloring are just perfect.. as this Box is for my Daughter and her favorite color shade is pink
Thank you minixfreak for your work.
Best Regards,Last edited by polosolo; 27 August 2019, 01:47.
Yes it defiantly performs much sweeter
One thing I have notice with both the the revised and the other standard edition on my H96 PRO+ is .......... major WIFI problems ..
I must apply the QC9377_BT_Fix and everything then works well....................But after a few hours of using the WIFI with the box.....it then disconnects and I have to then re apply the QC9377_BT_Fix vis TWRP to get it to work again on WIFI ........... If I go to the box WIFI setting the tab is Disabled and even trying to toggle enable it...it does not function and reverts back to off.
So I reapply the fix via TWRP .....Then again after a few more hours of testing.... I have to perform the same scenario again........No matter what I do ...I must always re-apply that fix as it never sticks.
Now ...that`s no going to be a problem if you have the box hardwired to the network...But it is a Major problem if you want to use the box with WIFI Standalone.
This could be specific to the H96 PRO+ versions of the box ..
Best Regards,Last edited by polosolo; 27 August 2019, 20:27.
Originally posted by soldiaz View PostI had faced wifi issues too (did not find network) but since then no issues at all. Very stable on my TX92
No problems if you plan to do a hardwired connection ..Like I will be doing ....So it will be usable in this state for me.
Best Regards,Last edited by polosolo; 07 September 2019, 03:19.
Guest
Hi Guys,
Well the Minixfreak rom has one of the best looking startup screens I've seen in a long time, but the problem is I can't get past it. I knew the USB ports weren't working, but I figured I do what Antonio suggested and use a hub on the otg port, it's not working either. So right now I"m looking at my screen and see the Minixfreak logo, and the question about what launguage to use, and that's it. I can get into TWRP using the sdcard, but even doing that I have no usb ports working at all. Kind of at a loss as to what to do next, any idea's
Krissy
Hello Guy`s,
Please can anyone tell me if it is possible to add app sources to the recommendations row list home screen to mininfreal OS S912_LPDDR_REVISED.img ?
I will explain..... Let`s say I do not use the play-store to download the app and use a 3rd party app not designed for the Android TV.... Example: zionTV or Cinema-HD apps ..Now once I have installed these`s to the OS ..they don`t show up in the Home recommendations row tab within the settings , so I can select them ?....is there a way for me to add them in either via some hidden settings or manually via a file browser ?
Any help or feedback would be most helpful. Thank you.
Best Regards,Last edited by polosolo; 07 September 2019, 04:54.
Krissy
Guest
Originally posted by polosolo View Post... it is possible to add app sources to the recommendations row list home screen ...
This tool creates banners for sideloaded apps that don't show up on the home screen.
There are currently 1928 users online. 0 members and 1928 guests.
