Originally posted by clarkss12 View PostDHL works great for me. Three days from China to my door in midwest USA.
??????... friggin conspiracy. I got a feeling trebor told the Chinese, that I have predilection for Macs. 8<0Kris....don't forget my boxes! Okay?
Originally posted by Silver View PostHave to pay 47 customs fee to dhl, wasnt worth it for the wait time.Kris....don't forget my boxes! Okay?
Originally posted by ClarkKent View Post
Ouch!! 47 euros on $145 item? I don't think you're getting your money's worth from your government. Pretty sure they're selling out to China, and they're making you pay upfront.
Anyone else having problems installing ota update 0.2.9 usb fix?
it says not valid update package, box is rooted and magisk is.installed
Well its like that, nobody sells device in my country so i had to order order from china.
So you have to disable and uninstall it first.
Originally posted by Silver View PostAll set up working, magisk working good, cannot pass safetynet but overall nice device with good featuresKris....don't forget my boxes! Okay?
Wouldn't you also say that it's one of the most consistent smooth operating boxes you've used? I don't remember if you had a shield, but other than that ... if you know about a stronger more consistent and smoother box, tell me
Sometimes settings app crashes but no problem, wifi very good, but as we all know, firefox + anon imageboard (like 4chan) will get the cpu to lag.
Will buy one more
@Everyone
there is new firmware update for ugoos AM6 TV Box:
1. Added support of multichannel PCM audio in HDMI
2. Fixed playing of big MP4 HTTP streams
3. Fixed HDR10+ work
4. Added conversion from HDR10+ to HDR10, if not supported
5. Now, Dolby Vision enables only when source is Dolby Vision and added setting for force enable Dolby Vision
6. Added conversion from Dolby Vision to HDR10 if TV not support Dolby Vision and support HDR10
7. Hide Dolby Vision settings in case if not supported by device
8. Disabled SDR to HDR by default
9. Added color mode setting for 4k50-60 Hz modes
10. Some changes of color modes in auto mode for bad HDMI cables
11. Some visual changes of Color mode settings
12. Fixed some HDMI hotplug bugs
13. Added saving resolution and color modes for OTA updates
14. Added write to external storages permissions for apps (CIFS, NFS clients)
15. Added security option to CIFS client (Authentication protocol)
16. Added support of SMB2, SMB3 to CIFS client
17. Fixed getting state of client (CIFS, NFS) if there are spaces in name of shared folder
18. Fixed long shutdown if CIFS client connected via Wi-Fi
19. Fixed bug of general unmount for CIFS, NFS clients
20. Some improvements of mount CIFS, NFS clients after network connect
21. Changed some strings for CIFS, NFS clients settings
22. Fixed saving volume level for bluetooth devices
23. Fixed SPDIF passthrough for using auto surround setting
24. Added ability mute of HDMI and SPDIF sound
25. Moved power action settings from Screen saver to Power in TvSettings
26. Added 1 minute for screensaver timer
27. Added 5 setting volume regulator steps
28. Added Belarus localization support
29. Some improvements of Update Service
30. Fixed location settings for new google play services
31. Hide virtual device of ATV remote service in Gamepad settings, Input devices settings
32. Fixed rare bug when display mode did not return with system AFR function
33. Fixed SPDIF sound clicks on X3
And 0.3.1 additional updates:
1. Fixed CPU load problem
2. Re-hide Dolby Vision settings
tested and working goodthanks to ugoos!
There are currently 1783 users online. 0 members and 1783 guests.
