I already flashed GT1_708N0_AT_V1A earlier. May I know how can I update to this version? My box went to TWRP each time I start the box with reset button clicked (for SD card method).
[ROM] Beelink GT1 Standard & Ultimate Android (7.1.2) ALVATECH (Both 6255 & 9377)
Please make sure you format the card with the Burn Card Maker when you prepare SD-Card. Now, If you made the SD-Card with the Burn Card Maker properly, then keep the box turned off while you plug in HDMI cable and put in the SD-Card into the box. Then plug in power cord into box while holding down the reset button on the bottom of the box. Make sure as soon as you see the Android logo with status bar at bottom let go of the reset button. If for some reason you don't see anything at all just leave the SD-Card in the box and wait for about 15 min to be safe and it should automatically restart if you setup your SD-Card this way. There is an option for reboot, make sure that the check box is checked when making an SD-Card image. If you like you can PM me for some more help if needed.
Thank you,
Alvatech
Originally posted by cool31 View PostHello,
Where I can see my SN?
My GT1 is a classic one S912 16GB.
I do not have any sticker to get the SN?
I see only in the parameter : GT1_106MO
Can I use this ROM?
I can't tell you for sure but it looks like you have an older GT1-Ultimate box with Android 6. Usually there would be a sticker on the bottom of your box with a serial number. Then you can compare to the first post to find out if you can install the ROM. But from what I could tell it looks like this ROM would be the one that would work for this box, But this is something you would have do at your own risk. You could always go to Beelink's site and ask for help to identify your box. If you decide to flash your box, you would need to use the USB Burning Tool since you'll be upgrading from Android 6 to 7. This is the only method that can be done when upgrading from 6 to 7, the SD-Card method can not be used.
Thank you,
Alvatech
Originally posted by icekrim View PostHi i've installed this image with usb burning tool 2.0.9 but now after the boot screen Alvatech, i've a black screen and after a restart nothing.
i can't also access anymore to the recovery with the reset pin
is there a way to reinstall the recovery?
Thank you,
Alvatech
Originally posted by ALVATECH View Post
The best thing I could tell you is to make sure you are putting the right ROM on your box. Make sure SN on box matches the proper ROM. Also maybe try using a newer USB Burning Tool 2.1.7.0 and then try to flash again. If you can't load Android OS and can't boot into recovery then best thing to do is to re-flash the box again.
Thank you,
Alvatech
Thanks for your quick answer, my box is with SN : AX12 , board version is GT-F ver2.0. i've reached to flash an ATV rom with the help of the 2 pins to be connected (by a small screwdriver i.e).
i confirm that on this box power supply needs to be connected (power from USB seems to weak), if not connected : USB burning tool will stop with an error at 7%
So connect USB cable and power supply and put the screwdriver on the 2 pins no more than 1or2 seconds until you hear box detected by windows.
It worked for me but i've still no recovery installed (tried to boot with reset button at start with no success)
i will try your rom; it seems GT1_709N0_AT_V3A is the good one for my box.
Originally posted by moebeman View PostHi,
Thanks Alvatech for the new rom - works great!
Quick question, I'm planning to buy a 256gb microsd (sdxc), will my gt1 standard (16gb) support it?
Thanks everyone
you're welcome. I'm thinking these boxes can only handle an SD-Card of 64GB max. I remember one time posting it here a while back. But all my posts got deleted, so I can't reference anymore.
But I'm pretty sure that's what it was.
Thank you,
Alvatech
According to this forum: http://www.bee-link.com/forum.php/fo...hread&tid=1058 it supports SDXC. However I only have 64 GB microSD, so I am not able to confirm it.
Originally posted by sribou View PostHi,
I have stutter with the Bluetooth (tested with different headset). My device is A912 with chipset 6255.
Is there a way to fix it ? I see that on the other 7.1.2 in the forum, it was fixed. Do you know how ?
Many thanks.
Regards.
If you see the first post of this thread I have a patch there, this is for Bluetooth stuttering issues. Hope it works for you.
Thank you,
Alvatech
Hello,
Thank you,
Alvatech
Thanks for your reply but your patch AT_7.1.2_BT_QC9377 is not for 6255 if I am right. So, I tried and I have no more issue with sutter but now with connection/disconnection in continue
Thank you,
Alvatech
hello alvatech , I flashed a GT1 Ultimate 32GB/3GB with S/N AX12 firmware 708NO using this firmware ( GT1_709N0_AT_V3A.img )
flashed with pc using usb a cable . usb burning tool v2.1.6.8
during formatting it stopped at 7% . i tried several times and always got same error .
i then unticked ERASE BOOTLOADER and it flashed fine .
There are currently 1633 users online. 0 members and 1633 guests.
