Any ways to unroot this ROM? I need to install streaming apps (AstroGo), but it detected my box as rooted.
[ROM] Beelink GT1 Standard & Ultimate Android (7.1.2) ALVATECH (Both 6255 & 9377)
Your best bet is to go the Extra Tips Section (2nd post) of this thread and read on how to get Magisk installed. This will hide root in most cases. Hope it works for you.
Thank you,
Alvatech
Originally posted by ALVATECH View Post
Hello,
Thank you,
Alvatech
Too bad this apps is checking if Magisk is installed too
Thank you,
Alvatech
Link to un-root:
You might try link down below to un-root your box. But to be honest I don't think it will make a difference, and then you might need to re-root or re-flash your box again if you find out it didn't work for you.
Thank you,
Alvatech
Link to un-root:
https://androidfilehost.com/?fid=24352994023708732
Originally posted by cageyone23 View PostSigned up to a big thanks for your amazing ROM..it works like a charm and then some...Cheers for the hard work
Thanks again,
Alvatech
Originally posted by cageyone23 View PostHi im using a Mele F10 air mouse to control my GT1 and previously I could put box into standby by pressing the power button. Does your rom support this option and if so how do I enable it?
Cheers
All good, just worked it out
I can't remember exactly on this ROM since this is an older ROM now. But I think it was already setup this way. If you press the power button on the remote it goes into standby. If you need further help you can PM me and I can see if there is something else I can help you with.
Thank you,
Alvatech
Hi Alvatech!
Installed this rom on my Ultimate G912. Everything is fluid and works well, except something "basic": I did choose Nova as Launcher. On first menu, i can use controler to jump from Kodi to You tube.
But when i press the central icone to the other applications, mouse control doesnt work and i must use mouse....
Im i missing something?
P.S. Box program also doesnt work....
Not sure what you're referring to exactly. But it looks like you're asking about pushing the center button on a remote to click an app and it's not working for you. If so what kind of remote are you using? I have the stock remote and use it and I can move around choosing different icons and then when I click the center button it opens the app. I no longer use Nova Launcher due to some compatibility issues I've noticed. I now use Square Home Launcher, this ROM seems to do a lot better and supports a lot more Android versions too. This ROM is one of my older ROM's and at the time Nova Launcher is what I pre-installed in my ROM's. Also if you're referring to showbox app, yes that app is no longer working and you can just remove it. Like I've mentioned this is one of my oldest ROM's and a lot of apps have changed since then. You would need to change out or update certain aspects of the ROM due to changes.
Thank you,
Alvatech
Hello,
Thank you,
Alvatech
Thanks for answer. Yes i use original command. On the beginning menu, with Nova, i can use remote buttons to navigate.
When press middle button to change page, to were normally are all the applications, i lost access to buttons to use command buttons. Mouse option works.
Ok gonna trt to install Square Home Launcher. Need find now APK.
Thank you!
P.S Square looks a big mess. Try another native launcher and now everything works smooth.....thank you!!
Hi Alvatech!
Thank you!
Hi ALVATECH,
? first of all thank you so much for your work. The original firmware for this box is extremely instable and the company doesn't seem to care.
I've used you firmware for a few days and is rock-steady!
I have a Q for you. I see that the GT1-A has got Widevine L1 and you have been able to keep this feature on you firmware as well.
Is it possible to add to other boxes, like the GT1 Ultimate or is it bounded to HW?
I'm trying to use my prime account to see HD contents but I think w/o L1 isn't just possible.
Thanks!
? MaxLast edited by Maxium; 08 December 2019, 23:40.
Originally posted by Maxium View PostHi ALVATECH,
?? first of all thank you so much for your work. The original firmware for this box is extremely instable and the company doesn't seem to care.
Thanks!
?? Max
Thank you,
Alvatech
There are currently 4492 users online. 0 members and 4492 guests.
