[ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad Android 9.0
    [ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad (Android 9.0)
    Hi, I present to you another ROM for this box.
    I've made 2 different ROM's for these boxes, for boxes starting with SN: 95X and another for SN: B95
    Please download the correct ROM for your box.
    Changelog v2.0:
    • built-in the TWRP recovery 3.2.3-1.
    • changed init.d mechanism
    • removed the ancient Chinese busybox
    • updated busybox and all its links in vendor
    • a newest SU binary is installed
    • installed patched SuperSu 2.82 that does not require updating
    • USB debugging is enabled by default, full AdbShell support, Selinux is disabled
    • Noise reduction disabled
    • Installed a program to manage the service Auto Frame Rate (afrd)
    • changed Framework. Cut out the System Tray, but left the Navigation Bar
    • 13 WiFi channels
    The following applications are added:
    • Opengapps Atv (at the very minimum)
    • App Drawer
    • Explorer X-plore, for remote
    • Alternative Market AptoideTV
    • GoogleChrome v.57. Do not update it, if you want to use copy-paste
    The second file in the archive is the md5 hash to check.
    Verified on the following devices:
    • - Beelink GT1 Mini (both revisions)
    • - Х96Мах 4/32 и 4/64
    • - T95Q
    • - Tanix TX5 Max
    On the last 3 boxes (old revisions), install 95X firmware.
    Want to buy me a beer?
    Download:
    Patch for T95Q and X96Max to control the serial remote control ->
    (install with TWRP )
    https://drive.google.com/file/d/15W-...ew?usp=sharing
    To users of T95Q and X96Max:
    with this bootloader, the power button from the stock remote control will work in your boxes.
    How to replace it:
    Code:
    su
    dd if=/sdcard/bootloader.img of=/dev/block/bootloader
    Install instructions:
    • Use USB Burning tool 2.1.7.0
    • Refer to Beelink own tutorial how to flash this box!
    Enjoy it!
    Thx man , let's test
    - Much faster and smoother than any Oreo versions before , fantastic job Sasvlad
    - only one problem : i cant boot from sd card in coreelec
      People ATV from Sasvlad v2.0 (Android 9.0)
      A short version of the test for the firm X96Max is an old version.
      Display do not work.
      After shutting down , it can not turned on with the remote control,
      Must re-plugged the power plug to turned it on .
      TWRP is not a USB flash drive showing 0mb.
      Ruski settings DroidTV (patch) - work
      Installed patches - T95Q_X96max-Android_9-Remote_Sasvlad.zip - works
      LAN, WIFI (5G and 2.4), Bluetooth - work
      SPDIF - works
      Sleep and HDMI CEC- work
      Youtube 4K - eat and work
      AFRD- works
      HDR - works
      It works very fast and with a good video image.
        You should flash a specific version of recovery. Then your storage will be shown up in recovery.
          Thanks a lot s a sasvlad for your wonderful work. It would have been better if you could have incorporated the remote patch also with this rom.
          anyway better than nothing. So far I am loving it. Very nice Rom and display works fantastic. It's super fast.
          keep up your tweak capabilities. If possible improve further
          thanks
            Thank you for this rom
              Sasvlad
              Nice job, any thought's on porting ATV to A95X F2, also very popular device.
                I really like this ROM but not being able to run coreelec my main program means I will have to go back to another ROM version.
                  Hi Sasvlad, why have you disabled default System Settings in your ATV Version ? is there a way to enable it ?
                  All i can see is the Droid Settings. its very difficult to go to Default Settings for customizing Display, Sounds, Network, Pointer Speed Settings etc.
                  Can you guide me on how to enable it pls ?
                  Thanks in advance. Otherwise its a pretty fast ROM. i am really liking it.
                    How to do it:
                    1. Explorer with root access go to the system\priv-app\Settings folder
                    2. kill everything there
                    3. put the contents of the archive there
                    4. set the rights on files - 644, on folders - 755
                    5. Reboot the box.
                    Download the Settings.rar
                      Sasvlad is it possible boot from sd card to be fixed ?
                      Any suggestion or way how to ?
                        tks
                          Work on km9 pro?
                            Originally posted by mAtvXk View Post
                            Sasvlad
                            A95X F2 ? ​​​
                              I tested on Tanix TX5 Max with 95X fw, the box can boot but it's stuck on wifi connect, on non atv vesion i can't turn on wifi too. Can you make a patch wifi driver for TX5 max?
