Many thanks for your reply, I forgot to tell you that I installed the rom via sd and pin method, maybe this is the reason for the malfunction of the remote control?
[ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad Android 9.0
Originally posted by Sasvlad View Post
Find for your box the Firmware on Android 9, in which this problem is not present, and port the Bootloader from there to my firmware.
Originally posted by robycop1098 View Post
Ok i find the beelink official firmware android 9.0, can you briefly explain how to port on your firmware. Sorry but I'm not very experienced :-(
After that, flash my firmware back, and through ADB ( or Terminal) replace Bootloader.
Originally posted by Mazerati View PostHi, that's strange. On my T95Q I can't seem turn off HDMI CEC, the box starts booting on once I turn on my TV (even though it's dsabled in the settimgs menu). I'd like to deactivate CEC completely. Is there a way to reliably turn CEC off ?
I had to disable CEC on my TV.
Enviado do meu POCOPHONE F1 atrav?s do Tapatalk
Hello all.
I successfully flashed this on my x96 max 4gb/64gb it works but I am finding the refresh rate is constantly changing, going through different menus or apps on the device itself. My TV goes black and picks up another refresh rate then works again. Is there some way to make this go away?
I don't have it turned on for any apps specifically.
Any idea where that setting is on the box itself?
In "display" then "HDMI" I think something like "adaptative"
In some firmwares you have off ;level 1;level 2
I think level 1 only changes refresh rate on full screen video.
There are currently 1598 users online. 0 members and 1598 guests.
