[ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad Android 9.0
Hi.
I have a gt1 mini new version. With Kodi, when playing videos in 21: 9 and enlarging them to 16: 9, the image is not scaled proportionally, but enlarged up and down, lengthening the faces and bodies, which is very annoying. Does this rom have that problem? Apparently it is because of the video codec, as I read.
Greetings from Paraguay!
Hello,
I've managed to install this ROM in my T95Q, also managed to apply the patch for the remote and the bootloader.
I am still trying to figure out how to solve some issues with my external remote keyoboard (minor issue)
In general is a great improvement!!! thank you very much for a great ROM.
However anybody can help me to "light off" the bluelight of the device which is ON all the time?
That's a bit annoying.
Thanks in advance
Thanks in advance
Originally posted by Sasvlad View Post
Unfortunately, I don’t have a software solution to this issue. But you can disassemble the Box and turn off the LED using a soldering iron.
As I said, geat ROM; thanks a lo for the big effort.
Originally posted by Sasvlad View Post[ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad (Android 9.0)
To users of T95Q and X96Max:
with this bootloader, the power button from the stock remote control will work in your boxes.
How to replace it:
Code:su dd if=/sdcard/bootloader.img of=/dev/block/bootloader
i followed the steps using USB Burning Tool, search in youtube.
Patched my remote by copying the remote config to /vendor/etc. remote is partially working now, but power ON not working.
i tried to patch bootloader as per the instruction, but nothing happens.
what i did was, i installed terminal and gave it root access.
i executed the commands as per instructed.
but when i browse root using xplore, the dev/block/bootloader remained the same (size not same with new bootloader.img)
what did i miss?
How to replace it:
I have T95q 1st revision and i have to say, that firmware is working perfect (thank you Sasvlad). The only "bug" i found is the problem with MPEG4 kodek, but i think that this is Amlogic problem with android 9.0 for s905x2 (on different boxes). It is working normally on android 8.1.
Originally posted by hajvaniboy View Post
Sorry can anyone please describe a little how to do it (power button problem). I just don't know how and where to do that.
There are currently 2141 users online. 2 members and 2139 guests.
