[ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad Android 9.0
Originally posted by Sasvlad View Post
Thank you Sasvlad .
If you could also point me towards the right options to select before making the card please I would greatly appreciate it - just trying to avoid a brick!The options available are:
To Partition and Format - Y/N
erase_flash - Yes (erase in normal / erase in force / erase in total / forcely erase all)
erase_bootloader - Y/N
Reboot - Y/N
Also, another quick (and maybe dumb) question - if we're flashing with the USB Burning Tool, does the box need to be entered in Recovery mode first? I assume yes but I don't see it mentioned in the Beelink tutorials that's why I'm asking. This is for a GT1-mini btw.
Thanks again!
Thanks again!
Originally posted by TheBlackening View PostHave you looked into the droid settings (not the normal settings)
In "display" then "HDMI" I think something like "adaptative"
In some firmwares you have off ;level 1;level 2
I think level 1 only changes refresh rate on full screen video.
Enviado do meu POCOPHONE F1 atrav?s do Tapatalk
Flash it and check how your remote works with this firmware. If everything is ok, using ADB copy the bootloader block and save it on your computer.
After that, flash my firmware back, and through ADB ( or Terminal) replace Bootloader.
I am trying to do the same manipulation.
I have difficulties to "backup" and "flash" the bootloader using adb/fastboot because I don't seem to be able to connect to the debug using the male-to-male USB cable.
All I managed to do is to backup the bootloader via remote--> adb connect xxx:xxx:xxx:xxx:5555
su -c "dd if=/dev/block/bootloader" > /sdcard/bootloader.img
But once I reboot to bootloader (in order to flash the bootloader) I cannot connect to the device anymore remotely....
So I am a bit loss
Can you help me?
thanks in advance!
Originally posted by moabile View Post
Hello,
So I am a bit loss
Can you help me?
thanks in advance!
su
dd if=/sdcard/bootloader.img of=/dev/block/bootloader
Or you can copy this file through the root explorer at /dev/block/
Similarly, you can remotely execute the reverse command:
su
I am now able to TURN ON the Beelink GT1 S95X with the REMOTE on your Android 9.0 Roms!
if someone is interested-->
original bootloader: link for S95X version
https://mega.nz/#!ZxEGCIIb!em_4kZznD...AsbJxKIe89zn6Y
Commands should be something like:
adb connect xxx.xxx.xxx.xxx:5555
adb push "C:\download\bootloader_ori.img" "/sdcard/"
adb shell
su
dd if=/sdcard/bootloader_ori.img of=/dev/block/bootloader
reboot
Originally posted by Sasvlad View Post[ROM] Beelink GT1-Mini (and some others) AndroidTV v.2.0 by Sasvlad (Android 9.0)
Hi, I present to you another ROM for this box.
I've made 2 different ROM's for these boxes, for boxes starting with SN: 95X and another for SN: B95
Please download the correct ROM for your box.
Changelog v2.0:- built-in the TWRP recovery 3.2.3-1.
- changed init.d mechanism
- removed the ancient Chinese busybox
- updated busybox and all its links in vendor
- a newest SU binary is installed
- installed patched SuperSu 2.82 that does not require updating
- USB debugging is enabled by default, full AdbShell support, Selinux is disabled
- Noise reduction disabled
- Installed a program to manage the service Auto Frame Rate (afrd)
- changed Framework. Cut out the System Tray, but left the Navigation Bar
- 13 WiFi channels
The following applications are added:- Opengapps Atv (at the very minimum)
- App Drawer
- Explorer X-plore, for remote
- Alternative Market AptoideTV
- GoogleChrome v.57. Do not update it, if you want to use copy-paste
The second file in the archive is the md5 hash to check.
Verified on the following devices:- - Beelink GT1 Mini (both revisions)
- - Х96Мах 4/32 и 4/64
- - T95Q
- - Tanix TX5 Max
Want to buy me a beer?
Download:- DOWNLOAD HERE THE GT1-Mini AndroidTV v.2.0 by Sasvlad 95X
- DOWNLOAD HERE THE GT1-Mini AndroidTV v.2.0 by Sasvlad B95
Patch for T95Q and X96Max to control the serial remote control ->
(install with TWRP )
https://drive.google.com/file/d/15W-...ew?usp=sharing
To users of T95Q and X96Max:
with this bootloader, the power button from the stock remote control will work in your boxes.
How to replace it:
Code:su dd if=/sdcard/bootloader.img of=/dev/block/bootloader
Install instructions:- Use USB Burning tool 2.1.7.0
- Refer to Beelink own tutorial how to flash this box!
Enjoy it!- 10. Added DTS-HD and Dolby TrueHD passthrough support in Kodi, VLC
Which version of this feature can be supported? like Ugoos X2, Iundefinedm sorry for my English.
Hello,
any solution for T95q not working wifi and bt? I installed SN: 95X version with USB Burning tool 2.1.7.0.Last edited by hajvaniboy; 12 October 2019, 12:26.
I'm sorry.... the link redirects me to root of tools. And please is there any tutorial how to change drivers. I now know that i have 2nd revision of T95q (100M ETH). And by now i tried some custom firmwares and there is always something missing.
8.1 version (ETH doesn't work)
9.0 version (wifi bt and remote doesn't work)
Only on stock everything works except that there is limited google play store apps because of device...Last edited by hajvaniboy; 13 October 2019, 21:36.
There are currently 2332 users online. 3 members and 2329 guests.
