X96 Air Amlogic S905X3 Android 9.0 Media Player
Hi . . .
Thank you all for your responses, much appreciated
It's much more clearer now as to what i need to do
Many thanks ath156 ; Guest ; billouetaudrey
I will revert to update you later
PS. I will also subscribe to you individually as soon as i am setup
Best regards in the meantime
Originally posted by mAtvXk View Post
TWRP has nothing to do here, you have allready establish connection with tv box and computer trough USB Burning tool !
Download latest SlimBOX v8 firmware (AOSP or ATV), unzip file, start the burning program with .img loaded, connect usb cable while holding reset button and flashing should commence...
Hi mVtvXk
This just seems the simplest and most logical way for me (I think by having started from post #1 through, i lost my way as quoted in ath156)
I'm just downloading the latest as proposed and will install soon . . .
So, I'm starting right at the beginning again;
One final question (in the meantime until install) . . . should i first format the SD Card, if so, in what format . . or do i just delete everything that's on there at the moment through the PC and the Burn Tool will take care of it ?
Sounds silly, but just to make certain
Thanks again
Hi mVtvXk
Thanks again
For card +32Gb, you need this app : http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
Guest
Nivan0611 , bro first made up your mind, which method you want to use to install the firmware (.img); from card prepared with Burn Card Maker, or through USB Burning Tool using cable ???
Firmware Update Guide for Android TV-Box with Amlogic SoC [androidpctv]
Originally posted by mAtvXk View PostNivan0611 , bro first made up your mind, which method you want to use to install the firmware (.img); from card prepared with Burn Card Maker, or through USB Burning Tool using cable ???
sorry if I'm confusing you
I have gone your route . . .
Downloaded and extracted the rom and loaded it into USB Burning Tool . . . Everything went well loading it up
At the moment it is sitting on 3% Download UBOOT @38min now . . . Is it normal . . . It's not showing any errors
Do I leave it at that and just wait
Hi My Friend . . .
Thank you so so much . . . finally . . . its on and working
now i need to set the language to english, that's about all for now (I think)
Once again, may i take this opportunity to thank each and everyone who has assisted me . . . it was a mission, but we got it sorted out
Many Many Thanks
The ROM has booted . . so now i'm stuck on the language (I think that should be all for the day . . or shall I say, for now)
please assist in guiding me to change the language to default in english
Awaiting your kind responses
Many Thanks
Originally posted by Nivan0611 View PostOnce again, may i take this opportunity to thank each and everyone who has assisted me . . . it was a mission, but we got it sorted out
Many Many Thanks
Many Thanks
There are currently 4326 users online. 1 members and 4325 guests.
