X96 Air Amlogic S905X3 Android 9.0 Media Player
    Originally posted by billouetaudrey View Post
    You use ATV? You are on the launcher ?
    Hi . . . Apologies 4the delay . . . Yes I am
    However, what concerns me is that I download the latest version of AOSP and installed this version
    But . . . When I go on the box in About "Firmware version" it says SLIMBOX-ATV-ver8
    Should I have loaded ATV version first then flash again to get to "AOSP" . . . . or do u suggest i just leave it as is. If i leave it this way can i still load another launcher if i so choose. . .
      Originally posted by Nivan0611 View Post
      ...please assist in guiding me to change the language to default in english...
        Are all the slimbox roms for the X96 air rooted and or is there one without root
          They are pre rooted, enable / disable it on settings
            Originally posted by mAtvXk View Post
            Nice SS
              Much obliged
                Hi . . .
                Guest
                I have installed V8 as recommend by you and have no regrets, ThAnK YoU
                Question tho . . . I've installed the AOSP version but in my "About" section, I see X96Air-ATV . . . this cannot be correct ?
                Should I have installed ATV first, then do another flash with AOSP on top of ATV (same procedure as you have guided me) but then remove ticks " Erase Flash & Erase Bootloader" ?
                Thanks in advance
                  I think that's normal as by design, in previous v7 version you could switch between ATV or AOSP versions and vice versa by applying the patch.
                  It is likely that the ATV build is always done first and then patched to the AOSP firmware by the author ?
                    Thanks very much
                      If it's already on fat32, you don't need to format again
                      For card +32Gb, you need this app : http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
                      Thanks billouetaudrey
                      Much obiged
                      I'm open to any tweaks or sideloads to experiment with that you may wish to recommend
                        Yea I have tried that but video streaming services Netflix, Foxtel etc still detect the device is rooted even when its set do "disabled" and wont run
                        Is there a way to remove root completely ?
                        thanks thomo
                          thanks thomo
                          Maybe try to install Magisk Manager or supersu
                            HI, i have x96 air 4/32GB, When i got its play store and bluetooth is not working.
                            To get rid of this problem i finally decide to install costume ROM and that was with Ver(X96Air_P1_20191017-1536).
                            After the installation my device configuration change to 2/16GB .
                            But after that play store is working and Bluetooth is still not working.
                            SO plz plz plz help me out how to restore my device configuration which was 4/32GB and
                            which custom ROM should i install which support play store and Bluetooth working as well.
                              Are you sure you have P1 device?
                                the old buildnumber is which shown in about section is "BuildNumber x96AIR_20200311_1810@".
                                plz help me out regarding this
                                thanks for ur time
