X96 Air Amlogic S905X3 Android 9.0 Media Player
Yes, you are right, I had (past tense!!) the same thing, but I never knew because I did not use BT.
I quickly contacted the Russian site, and they knew the situation :-)
The thing is, our X96Air P2 is hardware wise almost the same as a N5MAX, except for the Bluetooth chip.
We need to install a seperate set of drivers for the Bluetooth chip, I will put the link in the following message.
It is a small zip file for the X96Air.
I installed them from TWRP, and now it does connect and it has a Bluetooth address.
Give me a minute to put the link up.
Leo
This should be the link: https://drive.google.com/file/d/1CBE...ppDyRx_ko/view for the Bluetooth drivers as an addition to the SlimBox ROM 2.1 when used on a X96Air P2.
Must be installed from TWRP as well.
Originally posted by Satbeginner View PostThis should be the link: https://drive.google.com/file/d/1CBE...ppDyRx_ko/view for the Bluetooth drivers as an addition to the SlimBox ROM 2.1 when used on a X96Air P2.
That's weird.
Here I installed it and I could switch on Bluetooth, and I could see the Bluetooth address under About, Status.
Also I could connect my phone....
I now have installed the 2.1 version of the ROM, and it goes well so far.
I think it might be even a bit more "fluid" than the previous one, also WiFI has good results.
So in short this is what I did:
put both ZIP-files on an SD.
Reboot into stock recovery
Update from EXTernal to load TWRP
Inside TWRP slide to the right using an Airmouse
INSTALL the ROM from SD storage (Select bij TWRP button right down corner)
Good luck,
Leo
Originally posted by MareCarw View Post
Hello, does HBO GO work on that rom?
Using a VPN I was able to play several trailers and free stream episodes.
Good luck.
@Satbeginner
Friend, wanting to get back to the original rom, do I need to upload it via cable? With the USB_Burning_Tool program, can I upload it via a microsd card?
It worked with me using the USB 3 port.
Hi, just one question: Are you sure you have a P2 version?
There are versions of the X96Air that do not have Bluetooth...
I will see how to check the version of your box
How to check ? On the original software, the device name X96Air_P2 wrote in the settings
Are you sure the installation of the Bluetooth .zip went ok?
If you install Aida64 from the Playstore, and you look under System in that app, do you see Bluetooth 4+ mentioned?
Maybe you can check using Aida64 first, and repeat the installation of the Bluetooth zip and check again?
There are currently 2424 users online. 0 members and 2424 guests.
