thanks
X96 Air Amlogic S905X3 Android 9.0 Media Player
Originally posted by lovacuzitu View Post
Just to confirm that problem with both of my boxes was loosed wi-fi antena. Opened box, taped it back and TV box works perfectly. So, if anyone have problem that TV box restarts when hooks on wi-fi network, this is solution.
One more thanks to Miro.
I have problems with the wifi on one of my units. The box don't restarts but the wifi can't start and just turns off. The wifi turns on only like 1 of 20 times. When wifi starts to work it works perfectly until restart. I have tried with wifi dongle that worked for some days without problem and out of nowhere the wifi can't start again even with inserted wifi dongle. The wifi dongle works with no problems on my pc so it's not fault. Factory resets don't help and I have installed slimbox rom but nothing helps.
Originally posted by kiro777 View Post
Hi, how exactly you taped the loosed antenna back?
Hi. Open your TV box and if you see loosed wi-fi antena (it looks like sticky tape) just tap it to plastic cover.
I have flashed the box with stock img file but didn't help. Wifi works only like 1 of 20 times and board seems ok to me.
Originally posted by RiCkLaR_atvX View PostFound similiar box, New July firmware may work on the X96air.... try at your own risk!
Direct download link:
https://1drv.ms/u/s!ArKioz4lbRJGlXGA...Ps6AE?e=P7U1X1
Originally posted by RiCkLaR_atvX View Post... same stock launcher after bootup,
It's good to be alive!
Originally posted by FlyNNN View PostSpeaking of the stock launcher ... I am not a fan. Can someone recommend a launcher reminiscent of earlier versions of Android where I can create folder shortcuts, place widgets, change background, etc. on the home screen? I HATE this Apple type of customization limitations.
ATV_Launcher_Pro by DStudio Canada (minimal fee for PRO, but also has a free version) is great launcher for a TVbox, but I also love Lawnchair-2 by deletescape so the TVbox makes my TV look like a Giant tablet (launcher is compatible with remote and mouse functions).
Guest
I bricked my device, so i can not test it, yes it should have some root switch, atleast that it says in descripton (changelog).
There are currently 2229 users online. 0 members and 2229 guests.
