X96 Air Amlogic S905X3 Android 9.0 Media Player
Originally posted by romcrazy View Post
Originally posted by johny163 View PostHi, can anyone help me? I bought x96Air 4 + 64 GB and I have a problem with Bluetooth, I get a message saying that bluetooth has stopped working.
Originally posted by ecobit View PostP1, P2, P3 hwersion clean, stable ATV9 rom: https://4pda.ru/forum/index.php?show...#entry91789616
I have a brand new X96 Air P3 with Rom: 20191204 - 1754.
I tried the custom Rom "X96Air_P3_20191220-2048_ATV9_davietPDA_v1.5". Didn't like it, a lot of USELESS apps!!!! Much more than the official. Removed same day.
Why the don't create simple and light Roms, and after anyone can add his prefered individual apps. (Gapps and a file manager are enough)
Unfortunately the official rom stuck every time I try to set different txt size on settings, and can fix it only by factory reset! After 3 flashes I let it as is.
Originally posted by RiCkLaR_atvX View PostThat is because the firmware uses old Android 9 code where the Bluetooth.apk is faulty, but it is fixed in newer Android 9 AOSP code. Tell your Vendor they need to supply you with a Firmware update or get a Refund.
Will I find such an update somewhere on the internet? I ordered on Aliexpress and the seller doesn't speak anymore. My device is X96 Air_P2
I run a rooted, reasonably clean ROM from the Russian site 4pda, I am happy with it.
The original ROM is craperdepap!!
Good luck,
Leo
Originally posted by Satbeginner View Post
Read a previous post by satbeginner, (that's me) .
Good luck,
Leo
If I have the name X96 Air P2 in Settings, do I need to look for the same Firmware "P2"? Can I upload P3? Can anyone help me with this in a queue so as not to damage?
https://4pda.ru/forum/index.php?show...#entry93085504
I use the SlimBox ROM
I have a P2 4GB 64GB 1000Lan and use this ROM:
I use the SlimBox ROMLast edited by johny163; 15 April 2020, 16:37.
There are currently 2264 users online. 0 members and 2264 guests.
