X96 Air Amlogic S905X3 Android 9.0 Media Player
    Originally posted by Atlas_co View Post
    Hi.. I saw this video..
    The x96 air with android tv firmware.. ..
    anyone have it or know where to get it ?? ..
    This Android TV 9 Firmware (FW) is cooked by DaiVietPda (from Vietnam). For commercial purposes, retailers in Vietnam are limited to sharing outward. I tried to extract FW from my box as a backup of TWRP so I could install it to another box through the Restore command of TWRP as well.
    Note: only applies to X96Air_P2_20191017-1917
    I am not responsible for the risks you encounter when installing or losing the warranty.
    Prepare:
    - Insert SD Card to TF slot
    - Download TWRP_3.2.2_Android_9.0.zip and save to SD Card
    - Download My Backup FW, extract it and and copy to the card, the path to the firmware on the card should look like this: TWRP\Backups\1234567890\2015-01-01--07-26-31_X96Air_P2_20191017-1917\many files.
    (Before starting experiments with firmware, it is recommended to make a full backup of your firmware with TWRP. Tick everywhere except for the system image and vendor image sections, because they are duplicated.)
    Through the Power menu app or Reset (hold reset button - inside AV hole - when pluging power), we go in stock recovery
    Move the mouse Apply Update From EXT.
    Update From SDcard.
    Browse to and click on the file TWRP_3.2.2_Android_9.0.zip
    As TWRP boots up, click "Restore / Restore", browse to the firmware located, until you see the sections for recovery, tick should be everywhere, swipe and the firmware has install.
      Prepare:
      Update From SDcard.
      Are you saying that you have made a copy of the firmware with android tv ?? .. if so .. I will try it
        Yes, you can try. Note: only for P2, check yours before try.
          Wonderful !! .. I am very grateful .. it worked. Thank you very much!!
            Cheers!
              Prepare:
              Update From SDcard.
              Thank you so much for your sharing. I just tried and the system works pretty well. But only one thing - the system is not rooted. Hope anyone can share how to root the system or the rooted firmware.
                Here you are (check your revision of your tv box before install right firmware):
                For X96Air_P1_20191017-1536: https://mega.nz/#!xo0iTKjB!5GY4NaT0q...opWL6sed0gEdO4
                For X96Air_4GB_P2_20191017-1917: https://mega.nz/#!wp9zUIQZ!z18jZlW2r...53pJSkRsiXPg8Q
                Thanks for lekha7777 in pda.ru: https://4pda.ru/forum/index.php?show...ost&p=91789616
                  This one is rooted! Thanks nvuphi!
                    my tvbox stock firmware is X96Air_20191017-1108
                    is there any rom with androidtv for 2gb ram?
                    thanks.
                      I bought an X96 Air Amlogic S905X3 4G 64G and it will arrive soon. I am especially interested in Kodi, Netflix, Plex and Amazon Prime Video.
                      Do you know of any Netflix application that works for the device?
                      And something useful for Amazon Prime video?
                      I don't care if they are old or manipulated, the case is that they work.
                      Thanks in advance
                      And forgive this English translated from Google, I only know Spanish
                        Have to flash with ubt or i can do with twrp? Sorry my English not well
                          ubt.
                            How do you install rooted rom ? By using UBT or Twrp?
                              ubt.
                              So have to have male to make cable ?
                              Thank You!
                                Thank You!
                                Buy male to male cable USB then do the following:
                                https://youtu.be/TdId2INmhFs (Vietnamese)
