Hoping this fixes the USB issue.
X96 Air Amlogic S905X3 Android 9.0 Media Player
Originally posted by RiCkLaR_atvX View PostHmm... looks like the new WeChip V9 with S905x3, but that comes with LPDDR4 and this only comes with DDR3. The voice-remote does look nicer though. Did some digging and it looks like X96 is due to release an S922X box soon, if not by end of year then first quarter of 2020. My verdict is skip this "Air" due to the fact of the low budget DDR3, only 100MB Lan, so get the WeChip or Beelink GT-mini(2) if you want S905x3 with LPDDR4 included.
i'm looking to buy one on amazon? did you see one w/ DDR4?
i'm trying to replace my T95q...video color is bluring with redness everywhere.
below is the link...image is DD3 but descript is DDR4.
Originally posted by Air80 View Post
X96Air_P2_20191017-1917_vita911.rar
should be run through TWRP
Installed:
SquareHome Launcher + IconPack / Live Wallpaper / Weather / Youtube 3 views + stock / HD Videobox / Deezer / TuneIn Radio / GlavTV / TV + HD / KinoHD / PeersTV / LimeHDTV / DTV / LazyIPTV / LMDeluxe / TorrServe / Fry! TV / ParomTV / RT-TV / KinoTrend / KinoTor / SeasonHit / Ace Stream / AdAway / VLC Player / KMPlayer / ViMuPlayer.
Excess / unnecessary can be deleted independently. In SquareHome, this is done simply, on the "application" screen a long tap on the icon and in the basket.
Silent butanimation, lower navbar installed.
To display the weather, indicate your location in the application Transparent clock weather
Tools:
Blutooth icon on the desktop: one click on / off. Long tap - open the settings window / add new bluetooth devices.
Settings icon: one click - Droid settings. Long tap - Setting up an account, applications, "white" settings.
"Broom": one click - CleanUp quick memory cleaning. Long tap - SD Maid spring cleaning.
Originally posted by ecobit View PostP1, P2, P3 hwersion clean, stable ATV9 rom: https://4pda.ru/forum/index.php?show...#entry91789616
Hello.
I've bought this box a couple of days ago and now the wifi is not working at all.
Some of the times it doesn't turn on at all and some other times It doesn't find any networks while my other devices do.
I had performed factory resets multiple times with out any success.
Fortunately the seller will refund me but since the box is still functional, I was thinking that maybe I could use an external Wi-Fi USB adapter. Anybody has tested any adapter successfully? I've tested two older devices and none of them worked.
Any ideas? Thanks
Hi, I've read on the 4pda (russian) forum that loosing the WiFi probably is caused by putting something in one of the usb ports and pressing a bit too hard.
It seems that one of the usb connectors inside the box is almost touching the WiFi chip, and pressing too hard on this connector can cause the WiFi chip to loose some of the contacts with the PCB.....
I'm not sure if there is a WiFi dongle that works.
Un saludo,
Leo
Originally posted by Satbeginner View PostHi, I've read on the 4pda (russian) forum that loosing the WiFi probably is caused by putting something in one of the usb ports and pressing a bit too hard.
Un saludo,
Leo
Originally posted by kenduvernay View Post
That box is trash to start with. Don't bother with a WiFi dongle. If your seller will let you return, do it.
the box is sold with a crippled Android Mobile version installed, but by now there are several real Android TV versions available that greatly improve the overall performance and experience.
Any ideas? Thanks
Partially agree:
There are currently 1608 users online. 0 members and 1608 guests.
