X96 Air Amlogic S905X3 Android 9.0 Media Player
Originally posted by johny163 View Post
Thank you very much my friendI will be waiting
This will erase everything you have on the box.
It depends whether you already have TWRP recovery as a result of previous ROM's you have installed.
Both the ROM and TWRP can be dowloaded from here: https://4pda.ru/forum/index.php?show...#entry93085504
(I use Google Chrome browser, it has the translate build in, so I can "read" Russian :-)
ROM Link: https://drive.google.com/drive/folde...qeiPHv8uVwbp0w
TWRP Link: https://4pda.ru/forum/dl/post/183565...31_AML_ViT.zip
- prepare an Micro SD-card with both TWRP and the ROM on it.
- boot into recovery by holding the reset inside the 3.5mm and power on;
- load TWRP from SD-card if you do not have TWRP installed but still stock recovery;
- if you already have a TWRP recovery, skip the loading of TWRP;
- using the loaded TWRP install the ROM you also have on the SD-Card.
- Let the install complete;
- now reboot
This is basically it.
Let me know how you get on.
BTW, I still run the SLIMBOX-N5MAX-X3-ATV-OTA-for-20191119 version , I will install the ATV 2.1 myself tomorrow, to test that one too.
Success,
Leo
I now have installed the 2.1 version of the ROM, and it goes well so far.
I think it might be even a bit more "fluid" than the previous one, also WiFI has good results.
So in short this is what I did:
put both ZIP-files on an SD.
Reboot into stock recovery
Update from EXTernal to load TWRP
Inside TWRP slide to the right using an Airmouse
INSTALL the ROM from SD storage (Select bij TWRP button right down corner)
Good luck,
Leo
Originally posted by Satbeginner View Post
Hi, these are the few basic steps:
- now reboot
Success,
Leo
Hi Friend TWRP Link does not work. Do you have this version somewhere to send me?
I will send you a temporary link, wait a few minutes
and let me know if you could download it
I try to start it for a while. I have a question, if I want to go back to the original software, it can be done? Is it somewhere on the internet?
I will look.
But believe me, you don't want to go back :-)
There are currently 2478 users online. 0 members and 2478 guests.
